How old is your power steering fluid? Have you ever changed it? Does it groan on hard left, or hard right turns, or cold engine start ups?
I recently did a "Turkey Baster" treatment. I removed as much as I could out of the reservoir, I got about 10oz out. I replaced it with ATF fluid as the owners manual states.
Drove the car for 1 week, then removed another 10oz, refilled with fresh ATF fluid. Repeated it again after another weak.
I'm very happy with the results, no leaks, no groaning. I think this fluid change is often over looked.
Its cheap too, my 1qt of ATF cost 4 dollars and the turkey baster cost 1 dollar at the dollar store.
I'm hopeful I have extended the life of my Power Steering Pump. Winter is upon us, and mine has been quiet so far.
p.s. I realize this is not a total flush, some of the new fluid gets removed on the second and third extraction, but its not a "wallet flush" either!
Poll: Your Power Steering Fluid...How Old is it?
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
2000 V70XC - 131,000 miles
I installed a new power steering fluid reservoir over the summer, and took the time do to a modified flush as well! After installing the new reservoir, I left the return line off and attached a hose that left to a bucket. With the front of the car raised, I then had my dad turn the steering wheel lock to lock continuously as I slowly poured new fluid into the reservoir. The old stuff was a nasty dark green stuff (OEM - probably original). I used Mobil 1 Synthetic ATF as the replacement. A week or so after doing the flush, I did a couple more "turkey baster" drain+fills. I used probably about 4 quarts. Not too bad!
After the initial flush, the difference in the feel when turning was very significant. Steering was a lot easier and the occasional groaning that I had (leaky reservoir; had to top up often) was all but gone after the flush.
I highly recommended everyone take the PS fluid into consideration to be a regular maintenance item!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I too had the groaning until I replaced my power steering fluid. When I replace all of the brake hardware I am going to flush the power steering fluid and replace it with mobil 1 ATF.
C@lvin
- Year and Model:
- Been thanked: 2 times
I am second owner on both my current Volvos. To my knowledge the fluid has never been changed in either one. Other than the 00 V70 PS pump having a small leak, have never had any PS problems or symptoms. I did once put a small amount of (I think it was Castrol) ATF in the V70 to top it up.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
- misha
- Has thanked: 155 times
- Been thanked: 432 times
In Volvo owners manual says that steering fluid change is not required.It says just to add fluid if level is low.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FlyingVolvo
They also say that changing the transmission fluid is not required when it's pretty much proven fact that doing so will significantly increase the life of the transmission in most cases.misha wrote:In Volvo owners manual says that steering fluid change is not required.It says just to add fluid if level is low.
And why would you just top up if low? To my knowledge, the power steering pump/rack doesn't eat up any fluid, unless it's leaking... which might be due to bad fluid ruining it all.
2023 V60 T8 PE
2023 V60 T8 PE
- misha
I'm just saying what is written in owners manual.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
The owner's manual is wrong. A lot of cars from that era tried to claim they had low running costs by saying fluids don't have to be changed. On my 960 the coolant, ATF, PS fluid and diff oil are all 'lifetime fluids'. There is no such thing. All fluids must be changed eventually.misha wrote:I'm just saying what is written in owners manual.
Ambitious but rubbish
- 80 Replies
- 18791 Views
Last post by befarrer
- 5435 Views
- 51 Replies
- 8360 Views
Last post by mrbrian200
- 1519 Views
Last post by skippy764b
- 30 Replies
- 27451 Views
