Mobil ATF JWS 3309
KEWROCK
Year and Model: V70R 1999
Post by KEWROCK »
I was under the impression that you can't blend Mobil1 synthetic with fossil based ATF, especially Dex/Merc. The only other sythetic ATF I've seen that specifically said it was blendable with fossil Dex/Merc was Amsoil, But I wouldn't trust anything sold through a pyramid marketing scheme.
Every artical I've read on this site says you have to get every drop of fossil Dex/merc out of your system before adding mobil1 or Volvo branded JWS3309.(which doesn't make sense because mobil1 MOTOR oil was always fully compatible with fossil.)
Besides, in my region I have never seen mobil1 ATF on the shelves of any store. I've got Pep Boys, Autozone, Advanced, RS/Strause and a few mom&pops not worth mentioning. Walmart here only carries an off brand ATF(Pro something-or-other in a blue bottle). Mobile1 MOTOR oil is found everywhere though.
1999 V70R T5 AWD Red
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 74 times
Post by FlyingVolvo »
My 2000 V70XC doesn't require 3309, but I had no problems going from the slightly overdue dino fluid to Mobil 1 Synthetic ATF. I just did 4 drain and fills with no problems at all.
I think it's only the 01 and after cars that require 3309. Plus, I'd rather have a good synthetic one than even a good dino one. Transmission heat worries me a lot as I often go through 100+ degree heat. I'd rather have a fluid that is a little more resistant to thermal breakdown.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
850 Turbo1
Year and Model: 1996 Volvo 850
Post by 850 Turbo1 »
In terms of blending I don't know...But I believe if you drain and fill...drive 100 miles...drain and fill drive another 100 miles ...do this about 4 times...I believe you'll have expelled most of the bad stuff...I would think that using Mobil 3309 ....would be ok even if you have another type of oil in there...
I have just regular "ATF" in my car...some cheap stuff ....I've had it in the transmission for the last 6 months until I finally figured out that I should not have done that. I don't have any symptoms at all...but I'm about to drain and refill about 4 times unless I'm advised otherwise....
I'm in Canada where things are not as readily available as the USA...and I found Mobil 3309 everywhere I went...Maybe you could ask for those parts stores to order it...because I know they do order upon request.
So now...haha...I have the same question pretty much....is it safe to drain and refill with Mobil 3309 if previously I had just regular ATF??
1996 850 T5 Sedan
1996 850 T5 Platinum Edition Wagon
--Always Learning--MB--
850 Turbo1
ecbsykes wrote:My 2000 V70XC doesn't require 3309, but I had no problems going from the slightly overdue dino fluid to Mobil 1 Synthetic ATF. I just did 4 drain and fills with no problems at all.
As far as I can gather from this forum 3309 is required in all 850/s70 models...though I believe I've been lucky with regular ATF for the past 6 months :shock: :shock: 8)
1996 850 T5 Sedan
plainv70
Year and Model: 04 V70
Post by plainv70 »
No. JWS 3309 ATF is only required for post MY99 (2000 in the US) automatics, variants of the Aisin-Warner 55/50 transmission.
3309 is, however, backwards compatible with most ATFs, e.g. Mercon III, so it can be used with the pre-'99 cars, however, since it is much more expensive than the OE ATF, no one typically chooses to do so.
850 Turbo1
I stand happily corrected 8)
1996 850 T5 Sedan
