Hello,
Yesterday I changed all the turbo and coolant hoses on my 1998 Volvo XC70.
The job took all day.
When I closed the hood to test drive the hood felt odd when it closed. Or maybe I think that now. Or maybe I left a rag in there, or maybe not.
I returned from my short test drive, and I sought to open the hood again, it would not open.
The driver's side lifts up, but the passenger's side is stuck fast. From a search, it usually breaks the other way around. Driver's side cable breaks at the connection point and the hood won't budge with the hood lever.
If anyone has had this problem, or has a fix, please help.
Thank you
hood stuck
C@lvin
- Year and Model:
- Been thanked: 2 times
In the hopes that it's only an out of adjustment cable, enlist a helper and one of you pull up on the hood while the other pulls the hood release lever. If that does the trick, pull the kick panel off under the steering wheel and adjust the hood release cable (it'll require an open end wrench for the adjusting nut behind the lever).
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
- instarx
- Year and Model: XC70 T6 2011
It won't be easy and you may have to remove that cylindrical air conditioner thingy, but it you may be able to reach the latch from under the car. With pliers you may be able to pull the latch manually. If I can find my camera I will send a picture of the passenger side latch so you can tell where the lever is.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
- instarx
Here is a picture of the latch (looking toward the front of the car) with the two notched levers on the bottom. You can pull either one - the lever where the cable attaches or the empty lever on the other side of the latch. Both levers pull toward the centerline of the car.
Good luck. There is plenty of room on the driver's side but not much at all on the passenger side. It may not be possible to get an arm up in there. Maybe you can hook a looped clothes hanger around the inside lever. Hopes this helps.
Edit: Here is another idea. The hood release lever in the car only pulls the driver side latch, but that latch pulls the passenger side in turn. If you can reach the driver side latch maybe you can push on it's levers (to the outside of the car) and it will open the passenger latch.
2011 XC60 - sold
2011 XC60 - sold
airedale3882
- Year and Model: 1998 xc
OOORae!!!
Pop ed the the grill out (is reusable) and pulled on the cable. OPEN
Thank you to everyone/
rjongejans
- Year and Model: 1994 850T5
I have the same problem. The right side lock does not pop open. Cable is ok. I could get the cable from de other side and pull it with a plyer. However de lock does not open.
rjongejans
Anyone who knows a solucion? The hood is closed, only the open een few centimeters on the drivers side.
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
Hi,airedale3882 wrote: 07 Dec 2009, 19:11 OOORae!!!
Thank you to everyone/![]()
Very important to know, you can get to the latch through the grill?
I ask because i can get my grill out without too much trouble and not wreck anything.
1998 v70
- foggydogg
- Been thanked: 405 times
Try removing the turn signal assembly, and use a hook tool to trip the latch directly.rjongejans wrote: 06 Aug 2022, 21:04 Anyone who knows a solucion? The hood is closed, only the open een few centimeters on the drivers side.
Robert only shows the drivers side, but the same thing should work on the passenger side, unless the latch itself has failed - that would be pretty rare.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Just reach up between the drivers side headlight and the battery and push / trip the lever on the latch. That will release both catches. You might need a second hand pushing down on the passenger side of the hood. This assumes that your plastic air glide under the engine is already removed. No need to disassemble anything.
1999 V70 GLT
1999 V70 GLT
- 32 Replies
- 5802 Views
Last post by MrAl
- 676 Views
Last post by jreed
- 1574 Views
Last post by NickA
- 1536 Views
Last post by precopster
- 14986 Views
Last post by jaxomlong
