XC90 2003 Hood Release Latch broken
My hood release latch is broken and I am waiting for the dealer to get parts in. This morning I started my car and Warning light came on saying "Coolant low.Stop engine". Can anyone tell me how to locate my hood release cables to open hood and add coolant? If I remember right it was the passenger side that came unclamped, but I would like to know where both sides are located. Any help?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The catches are behind the headlights' inner edges.
The cable comes in to the driver's side latch on that side of the car. It then goes across the front of the car to the passenger side.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
well, I located the cable coming from the release on drivers side and followed it to behind the latch at front of car. pulled. drivers side releases but not passenger. after 2 hours under that car I still cannot locate the passenger cable that came out/broke to pull and release passenger side.
OEMVolvoParts
- Year and Model: ALL
Lisa you will not be able to find the cable going to that passenger side release latch. It is hidden on top of the radiator and runs across the front of the car. You have to lower the radiator to get access to that cable. It is an expensive repair, I believe it takes close to 4 hours of labor to install a new cable.
XC90 2003 My hood wont release from the safety latch on the drivers side. Where is the cable. i have the spent the last hours looking for the cable and trying play with the latch under the grill without forcing it.. I can't i identify the cable to pull? It looks like if i get the head light assembly out i should be able to get to it. Assistance please..
I solved the problem of the safety latch release. Afetr reviewing a few websites including this one was was most helpful. Use a long flat piece of metal about 1 inch wide insert between hood and car above light bulb. You will most likely need a flashlight. Push the latch hook down which is actually holding the hood.
I know this sounds easy and it is after about two hours of playing around with it.
THolland
- Year and Model: 2005 S60 2.5T AWD
- Has thanked: 3 times
Hi All, I have a 2005 XC90 and my hood release handle inside the car will not release the hood. I just had the AC serviced and the hood was working properly when I dropped it off - but not anymore!? I just noticed that the passenger side of the hood seems to be unlatched (I can pull it up slightly so know it is not latched) - but not the drivers side? When I pull the release handle inside the car I get no click, just steady pressure all the way until I can;t pull it anymore. I am not sure how to release the hood now and it is stuck shut. Kind of screwed here, and can't really prove that the shop caused this issue, just seems a strange coincidence? Appreciate any guidance.
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 26 times
- Been thanked: 134 times
Some else asked this question last August, see link for photos of the passenger side- https://photos.app.goo.gl/eRqyqF4G3X8CYfFU8
Driver's side is identical.
- 14 Replies
- 4500 Views
Last post by JimBee
- 4376 Views
Last post by MrAl
- 2599 Views
Last post by tekline
- 10 Replies
- 2703 Views
Last post by bmdubya1198
- 737 Views
Last post by oragex
