850glt 1995 missing
hey,im new 2 the site,just got my second 850(204 oookm's) but didnt drive the 1st 1 that much,the car seens to b missing or sputering at low speeds,driver side heated seat not working,d.s mirrior dosent defrost,burns a bit of oil,i need to remove the head light wippers,clock light,gear indicater light, needs replaced. any help with any of these problems would be greatly apreciated.icouldnt get the link for the 850 repair guide any sugestions? thnxs.
RockVegas
- Year and Model: 1995 850 Turbo Wagon
The miss, is it throwing any codes? If not, I'd just start with a basic tuneup. Change the distributor cap and rotor (use Bosh only), spark plugs (NGK Coppers, properly gapped), plug wires (bougicord), pil and oil filter.
Other things that can also cause a miss is bad or dirty injectors, bad engine coolant temp sensor, and a few other items.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Check the codes first,like this:
http://www.volvospeed.com/CheckEngine.php
After you read the codes,post'em here and we will try to help you out.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
I agree with the above, have the codes, if there are any, would help a lot. If there aren't any codes, then just do a full tune up. Make sure you only use OEM of copper plugs. All the others will upset the engine greatly.
As for the heated seat, is the switch lighting up? Are you getting power to the seat itself?
my lambda light cam on,(it was damp out)it was chugging at highway speed when it cam on,but was sputtering before that at normal speeds,i checked my A2 code and it came up 2,4,3? i checked a list of codes but could-not find this one.i reset the code and it seems to be better the light has not come on yet but i don't think i drove it a full cycle.does any one know this code or have any suggestions?thnx ROB.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Service manual
Gear shift bulb
Dash bulbs...follow the same basic procedure to remove the dash and console panel, then just change out the bulbs. The bulbs can be found here.
As for the other things, just search around the site, I'm sure everybody has had the same problems you've had before.
Gear shift bulb
'98 S70 T5
2016 Chevy Cruze Premier
- 1085 Views
Last post by matt122s
- 12 Replies
- 1721 Views
Last post by viper69
- 9 Replies
- 2254 Views
Last post by obayha
- 525 Views
Last post by Alan99
- 15 Replies
- 3292 Views
Last post by bmdubya1198
