Steering rack pinion seal
Pipes
Year and Model: V70 T5 1997
Post by Pipes »
UK 97 V70 T5
Is it possible to change the pinion seals with the rack in situ?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Unfortunately the rack needs to come out to change the seals. There is a terrific writeup here:
http://volvospeed.com/Repair/power_steering.pdf
If it isn't leaking badly I have actually fixed mine with automatic transmission stop leak fluid. The stuff that worked for me was Valvoline Max Life Automatic Transmission Stop Leak.
http://www.valvoline.com/products/brand ... op-leak/38
I sucked the old fluid out of the reservoir, put the replacement fluid in and ran the steering from stop to stop a few time and then repeated the process. While I didn't think it would work I tried it anyway and the rack hasn't leaked a drop since and that was about 2 years ago.
Pipes
Post by Pipes »
Sounds like a good plan to me,gotta be better than taking the rack out.I`ll let you know how I get on.
Volvofan94
Year and Model: 2002 Volvo S60 AWD
Post by Volvofan94 »
I'm sorry, I know this thread is kind of an older one, but how has the Automatic Transmission Fluid fix worked out for anyone with this problem?
I replaced both front sway bar links and noticed the subframe on near the passenger side steering was covered in oil again after I finished with my engine overhaul this year. Took extra time to clean up the subframe while the engine/trans were out of the car. Puzzled by where the leak was from, I grabbed my steering boot and noticed fluid was leaking out of the end of the boot. I wouldn't say the fluid was gushing out, but definitely at a steady dripping pace for about a minute. In this case, would it be better to replace the whole steering rack, try to replace the seals, or start off with the Automatic Transmission Fluid leak stop first?
If I did the ATF leak stop would that hurt other parts of the power steering system in the future?
Thank you for your assistance!
2002 Volvo S60 AWD - 2.4L I5, 167k miles - Daily Driver
1994 Volvo 850 - 2.3L I5, 160k miles. - SOLD
1994 Volvo 850 - 2.4L I5, 174k miles. - SOLD
Has thanked: 312 times
Been thanked: 818 times
My advice is to start with the ATF stop leak stuff that Lee mentioned. Many people have had success with it, that is the *only* place on the car I would feel comfortable adding a stop leak product. If that doesn't help, then the next step is to replace the rack, a rebuilt one would be the way to go. I have only done that job with the engine out of the car, I wouldn't want to do it with the engine in.
There may be a lot of fluid in the boot now but how quickly is it leaking? If the rate is slow then you may want to just live with it, but keep a close eye on it to see if it gets worse. Maybe the stop leak will at least slow it down.
Volvofan94
I will definitely give the stop leak a try. Hopefully it will fix the leak! :)
I don't think my car has a fast leak either. Been driving the car for a couple days now and the level hasn't dropped very far at all. I think I also made a mistake when I filled up the power steering fluid when the engine was Hot. Filled it up to the H mark and now it won't go down to C when the engine is cold. It stays just below the H mark. Will be removing the old fluid this weekend and refill with ATF stop leak.
Thank you everyone for your help!
Been thanked: 504 times
Post by cn90 »
Pipes wrote:UK 97 V70 T5
I agree with Lee that the Steering Rack needs to come out for a proper repair.
Below are some very nice info on Steering Rack, worth a read.
But see the link at the bottom of my post!
The bottom line seems to be TRW, SMI or Volvo rack only.No aftermarket!
http://forums.swedespeed.com/showthread ... ring-racks
http://www.justanswer.com/volvo/74z7s-s ... -rack.html
Rebuild kit:
http://www.pskits.com/catalog/rackvolvo-c-21_60.html
DIY:
http://volvospeed.com/volvo_repairs_how ... rvice.html
And apparently, you can renew the seals without removing the steering rack from the car!
http://www.ebay.com/itm/Volvo-850-s70-2 ... 0459551828
gregandterra
Year and Model: 1999 V70 XC
Post by gregandterra »
Tried the quick fix with stop leak on my 99 V70Xc, ended up dumping the whole contents on the ground a week later. Time to pull the rack and repair.
Followed the great tutorial found at VolvoSpeed, but discovered a few tricks.
1. With the jack supporting the transmission instead of the rear of the engine support, you can pry the support down a few extra inches when pulling out the rack.
2. After 15 minutes of struggling with the rack, said enough and pulled out the front sway bar. Took 15 minutes to release the bolts, and with it removed was able to easily slide the rack out where before the rear drive shaft and turbo down pipe we're interfering.
3. With all the open space, now was the time to replace the leaky turbo oil drain line that is next to impossible to reach with the rack in place.
I still have to renew the seals/o-rings and re-install, will post the results when done.
rcannon
Year and Model: 96 850 T, 08 XC70
Post by rcannon »
The rack repair link has changed- here it is.
http://volvospeed.com/pdf/power_steering.pdf
rrochell8
Year and Model: 850 Platinum Wagon
Post by rrochell8 »
I thought that this post had a link to someone who changed the right side seals with the rack on with pictures. Does anyone know where that link went?
850PlatinumWagon
