1994 440 No start
Hi I wonder if anyone can help. I have been left a 1994 Volvo 440 after a berevement in the family, it was stood for some 8 months. I went to collect the car & with a jumpstart it started fine, I drove it for about 300 yards & it stalled. It will now not turn over. I have fully charged the baterry & still nothing. If I disconect the wire to the strter in the harness & apply current to that it turns over ok, but will not start, I dont think there is a spark. It would be nice to be able to sort this problem rather than having to scrap the poor old thing. Its done about 59000 miles so should be good for a few more yet. Yours Reg
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Which engine is fitted?
Bill.
Is this the wire that comes from the ignition switch to the starter solenoid?If I disconect the wire to the strter in the harness & apply current to that it turns over ok, but will not start, I dont think there is a spark.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Hi sorry I am sure its the 2 litre engine & the wire is the one going to the selonoid so I assume it comes from the ignition switch, if I put a voltmeter on the other end & turn the key there is no voltage. Thanks for your help. Cheers Reg
- billofdurham
With a lack of spark and no voltage at the solenoid I would suspect the electrical portion of the ignition switch is faulty. Do all the warning lights come on when you first turn on the ignition?
Bill.
Bill.
Previously:
Previously:
- billofdurham
Sorry to keep asking questions but I don't want you to go out and buy any parts if that isn't the problem.
Bill.
I am assuming that you applied current direct to the starter solenoid when you did this. Was the ignition switched on or was it off? If it was off have you tried the same thing with it on?If I disconect the wire to the strter in the harness & apply current to that it turns over ok, but will not start, I dont think there is a spark.
Bill.
Previously:
Previously:
- billofdurham
One final check for voltage at the ignition switch. Check outgoing voltage with the key turned to the start position. It should be at least 8 volts. If it is 8 volts or more check the wiring from the switch to the solenoid. If it is less than 8 volts the switch is defective. You can buy just the electrical portion of the switch and it is an easy job to replace it.
Bill.
Bill.
Previously:
Previously:
hi sorry for the delay been hard at work. When I turn the key I am getting good voltage at the end of the ignition switch harness, it just doesn't seem to get to the starter. I also dont have a spark when turning over. Cheers Reg.
- billofdurham
If the voltage is at the ignition switch end of the harness but not at the solenoid end I would suspect a fault in the wiring to the solenoid from the ignition switch. Try running a wire from the ignition switch to the solenoid outside the harness. You could splice it into the existing wire using a Scotchlock connector, run it outside the car and connect it to the solenoid after removing the existing wire. Using the Scotchlock makes it easy to remove the wire after the test.When I turn the key I am getting good voltage at the end of the ignition switch harness, it just doesn't seem to get to the starter.
In your first post you said "I don't think there is a spark". Have you now confirmed there is no spark?I also dont have a spark when turning over
Bill.
Previously:
Previously:
- 16302 Views
Last post by Medusalith
- 17062 Views
Last post by volvolugnut
- 9731 Views
Last post by zoli440
- 16478 Views
Last post by pastoralia
- 11295 Views
Last post by andyb440
