Remote is preferred. If you do not have one, using the key in the driver's door will work as well.dcarlson12 wrote:Regarding the lock/unlock three times procedure, is this using the remote or ?
Thks.
2001 S80 T6 Siren Module 9452709 Replacement/Repair - How To Topic is solved
Fix Siren Module on 2001 Volvo S80
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
2008 S80 T6 AWD
1999 S70 GLT
Responsible for the care of a '92 960 and an '07 S60R
1999 S70 GLT
Crito
Here's a pic of the siren's code displayed on my BSR PPC diag tool. Only cost me $200 on eBay. Dealers charge a min of $50 to clear codes and I've already used it about four times.
- UEM-004 Siren
- ppcdiag.jpg (55.68 KiB) Viewed 11539 times
Hi, I've been having the alarm problem for some time now but it's really bad now. I bought the car used so I don't have a remote just the key. Well now the key won't open the car and the door switch will not unlock any of the door either. I checked the fuses and they are fine. I was thinking of going with an after market alarm system because that will give me keyless entry and I think it will be more economical than having volvo get me a remote. Now if I install the alarm systme myself do I still need to remove this module?
Crito
You can unplug the siren but there's a transponder in your key so you'll need to have another key made and tape one to the inside to the steering column to make the keyless system work.
I got my siren through parts.com for ~$150 but sounds to me like you're going to need a driver's door module too, which I got for about $350 from eEuroParts.com
I removed the door panel today and found that a little bar that moves the locks had come loose so everytime I turned the key there was nothing there to move. Replaced it and it came loose again cause the little lock that holds it in place had worn off so I had to improvise, so it would stay in place. As soon as it was back in place everything works again. I think I will replace the module next.
Crito
Yeah, Volvo parts ain't cheap, but with great threads like this you can save a ton on labor.
Nice howto! Wish I have seen it before going through the same
My siren was still working, but it had very, very low sound before I started to look for a solution.
I was removing it similar to the description, with the difference that I didn't remove the bracket. You can simply use a wrench to loosen the lower nut and take the siren out of the bracket. After dismantling, I found that mine was damaged just like the one on the pics.
I bought a replacement for about 20$ at an auto wrecker and installed it. I can confirm that no reprogramming is needed at all!
I just finised with my alarm siren replacing and it was very easy job with your howto
I had spare one to mount so it want take me too much time. And cause I had that spare mounting screws with square on the end I swap one with that security screw cause it had same thread
Thanks for help
volvo for life
- Year and Model: S80 D5 SE auto 2003
Hi there.In UK is cheaper to buy whole alarm set than only the siren.The difference is almost 50 pounds.Ask your main dealer about price and compare.It can save you some cash
- 2860 Views
- 2000 Views
- 12 Replies
- 748 Views
Last post by jonesg
- 2490 Views
Last post by oragex
- 730 Views
Last post by nascarmarc
