Location of thermostat.
This topic is in the MVS Volvo Repair Database » Location of thermostat T6 engine
Playn
Year and Model: 04 XC90 T6
Post by Playn »
Where the heck is the thermostat on an xc90 t6??
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I have split your post from the original thread as the question was different.
It is on the right hand side of the engine as in the attachment:
XC90 thermostat.pdf
(1.16 MiB) Downloaded 3073 times
If you need instructions for its replacement post back.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Playn
Post by Playn »
billofdurham wrote:Welcome to Matthew's Volvo Site.
XC90 thermostat.pdf
Bill.
Bill, Thank you very much for the diagram! I'd certainly welcome the instructions if you would like to post them. It is an 04 T6
Keith
billofdurham
Keith,
As requested:
XC90 thermostat replacing.pdf
(5.24 MiB) Downloaded 2342 times
Let us know how it goes.
Bill.
Previously:
Playn
Post by Playn »
Thanks!!
Playn
Post by Playn »
billofdurham wrote:Keith,
As requested:
The attachment XC90 thermostat replacing.pdf is no longer available
Bill.
Well I made it this far but for the life of me can't figure out how to get the timing belt cover off. Even with it off I'm not sure I can get to the Tstat behind the belt.
tstat 004.JPG (84.96 KiB) Viewed 11270 times
billofdurham
Am I correct in thinking you couldn't download the attachment?
I have just done it three times to check and it is OK.
You need a weatherstrip tool to get the timing cover off. You can either buy one or make it yourself from strong plastic strip.
If you are still having trouble downloading the attachment let me know and I shall email a copy.
Bill.
Previously:
Playn
Post by Playn »
No, I downloaded the attachments and have printed them out. I think the issue for me is that there is no screw attaching the front timing cover. There is apparently a small coolant line that needs to be disconnected so the cover can be removed and I'm not positive that even with the cover off the thermostat will be exposed. Am I going to have to deal with the timing belt at all?
tstat2 001.JPG (83.61 KiB) Viewed 11263 times
tstat2 002.JPG (83.85 KiB) Viewed 11263 times
Playn
Post by Playn »
I see that this small coolant line needs to be removed from a plastic nipple. The nipple appears to be an elbow. I think the nipple needs to come out in order to get the timing belt cover over it but I am not sure how to do it. What should be a simple job..... :(
trstjohn
Year and Model: 07 XC90
Post by trstjohn »
How long does it take to do this job? I had someone quote 8 hours? I've read elsewhere that it should only take 1-2 hours
Also, where did you get your parts from?
2003 Volvo XC90 T6
2007 Volvo XC90 3.2 (Wifey)
