850 turbo oil recommendation
FCPEURO
- Year and Model: 2006 XC90 V8
- Been thanked: 19 times
When I got my 94 Volvo 850 T5 in may, the PO was running castro dino oil. The car had 188K on it with a slow oil leak from the front crank seal. I switched to MaxLife and it made the oil leak worse. I ended up going to Mobil 1 High Mileage 10-40 and the leak as pretty much stopped at this point. This is the best oil I have ever used.
IVIUSTANG
- Year and Model: 2006 XC70
- Been thanked: 4 times
5W30 synthetic year round. Zero leaks, always use either a Mann or Amsoil filter. I usually buy the cheapest synthetic oil on sale. 220,000KM and I don't have to add a drop of oil in 5000 KM.
I may switch to Amsoil through their preferred customer plan and extend my intervals from 5000 KM to 9000KM after I do a UOA on my current group 3 synthetic at that interval. Is 0w30 not recommended for my car year round, or just for the winter or perhaps not at all?
- Jesse
- Jesse
1998 S70 T5 SE 290,000 KM sideswiped total loss(Sweet ride!)
2007 S60 2.5T loaded 63,000 KM SOLD!
2006 XC70 350,000 KM, 2" BadSwede lift kit, steel skidplate, Hilton Stage 1 tune, big burly tires
2008 S80 V8 245,000 KM SOLD!
2015 V60 T5 Premier+ 98,000KM
Hello, FYI Everybody: Don't overlook the ACEA ratings on the bottle. The "A3/B3" designates the presence of high temperature turbo charger bearing additves. Mobil1 0W-30 and Castrol 0W-30 European Formula are two examples- there are others. The occasional smoke-at-startup of a 1999 in the family stopped over two years ago when A3/B3 oil was used. A 2002 in the family has yet to smoke. They don't cost a penny more; you just have to find them. Good luck, George
Just was wondering if doing an oil change includes cleaning the TURBO on the 850T? If there were any leaks into the turbo would that cause any smoking at higher revs?
Is Quaker State high mileage 10W30 a recommended oil and what is people`s sucess in using this one?
Do people use any extra additives or seal conditioners in the oil change routine? I am on the west coast where we usually don`t drop below 38-40F.
thanks!
thanks!
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
There's a very passionate debate about oil/fuel additives going on right now. Personally I am against them but here is the link to the thread so you can read over what people have said and form your own opinion -> https://www.matthewsvolvosite.com/forums ... 75&start=0
As far as I know, generally the turbo is not cleaned out during an oil change.
Also, for Turbo's synthetic is preferable and many members suggest Mobile 1.
calbrit01
- Year and Model: 94 855 Turbo
My last oil change I used the Valvoline Synthetic Blend , think it was the 10W30 had the garage do cos I coulkn't be bothered. It started leaking again - soo back to the Mobil 1 HM...
94 850 Turbo wagon. Mobil 1 HM, K&N Air. 170Kmiles.
Navservice
- Year and Model: 2000 V40
I used Shell Rotella T6 from Walmart in my old (somewhat missed) 2001 Subaru Forester. The guy I bought it from (my brother) used nothing else. Walmart balked at putting it in at oil changes, I always had to sign a waiver. But they acknowledged how sweet the engine sounded at idle, this with 191,000 miles. Alas, due to less than optimal stability at high speeds, I wrecked it and have bought a Volvo V40 to replace it with. IIRC, the Rotella T6 I bought was 10-40W.
Navservice
Anybody who watches Scotty Kilmer's videos on YouTube knows that there will be a new classification of motor oil out in May of this year. It will be 0-16W and will have passed all kinds of rigorous testing. It sounds like the thing to get. I've considered using Mobil1 0-20W, they have a high mileage version (my V40 has 120,000) that contains engine seal conditioners.
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 129 times
I've used this in everything including a splash lube based lawn mower. I've never had a failure that was caused by lubrication. There has always been a different factor.alpha318 wrote: 31 Jan 2020, 18:55 I know I'm a few years late, but I have a curve ball for you all.
How do you all feel about Rotella T6?
A parts store around here recommends this in their parts list..
Frankly I think lots of oils are just fine. People often forget or choose not to change their oil and filter - then complain about the oil. Now a days, provided the oil pump and passages (o-rings in the pan?) are good, and your level & pressure is good, I think you'll rarely find an engine with lube based issues.
2023 Lexus RZ450e -66k
- 2312 Views
Last post by chrism
- 708 Views
Last post by pvfjr
- 20 Replies
- 5473 Views
Last post by Krons
- 29 Replies
- 9541 Views
Last post by cn90
- 22 Replies
- 2608 Views
Last post by Shinotheweevil
