740 turbo, 1990, rattle under hood
willwebster
Year and Model: 740 turbo, 1990
Post by willwebster »
Hi.
My 1990 740 turbo wagon has recently developed a rattle. The car has around 200,000 miles on it. It occurs between the speeds of roughly 15 and 60 mph. Accelerating, Braking, coasting, air conditioning, and the gear its in don't change the rattling in any noticeable way. The rattle is off and on. It sounds like metal rattling around metal. It ranges from light bell like sounds, to constant rattling, to nearly screeching. It seems to be coming from just in front of the dashboard, under the hood. I am curious how to fix this myself with minimum cost. Any ideas will help.
Thanks, Will Webster
DeRail
Year and Model: None
Post by DeRail »
Hi Will, welcome to MVS
I know I had a pretty annoying rattle coming in the dash that I couldn't really find for a while. I had taken the screws out, fixed what I needed to behind the ashtray and screwed it all back in. Apparently in the process the radio cluster moved down on one side ever so slightly and was causing a rattle 20mph and up, it was whenever it wanted to... backed out the screws, straightened it out and it's been right as rain. I'm just throwing it out as a possibility, have you done any work on or around the dash recently?
-Darrell
Howling
Year and Model: 1990 740 turbo
Post by Howling »
I had a rattle under my hood that sounded like it was in the dash. I'm not sure how loud yours is but mine was pretty annoying. Come to find out it was the heat shield under the spark plug wires. All I had to do was tightin up a few bolts and use some lock-tight and no more rattle. I hope this helped out.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Rattles can appear to be coming from one place but are then found elsewhere.
+1 on the heat shield but it isn't the only heat shield on the car. You will find them above the exhaust system, especially where it is near to the floor pan. They all work loose over a period of time.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
