95' 850 GLT Wagon
Where is the low pressure line located?
I have the charging kit and now just want to locate where the quick-connect fitting goes.
A/C Charging - Location of low pressure line
erich
I'm trying to recharge the refrigerant in my neighbors '95/'96 Volvo 950 T wagon but cannot find the low pressure quick-connect fitting. I've seen the description as to where it is supposed to be located but I cannot find it. I know i'm staring right at it but i just don't see it. Anyway, can someone take a picture of the area where the fitting is?
Thanks,
Eric
Thanks,
Eric
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The cap is in the form of an External Torx, which is fairly uncommon in most toolsets.
If you can't twist it off by hand, grab it from the top with some pliers and twist. Sometimes they get stuck. Don't crush the pliers too hard in your hand, and it shouldn't break.
'98 S70 T5
2016 Chevy Cruze Premier
