1994 850 sedan tranny fluid change
volvo850fan
- Year and Model: 850 sedan 1994
hello, I am on my second 1994 850 sedan. I am able to handle alot of mechanical issues but am stumped w/one. Can someone explain how the automatic transmission fluid is drained. My 850 has 127,000 miles and I am the second owner. I don't think fluid has been changed, would like to refresh fluid. Thanks to any reply.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Here's a whole write-up about the procedure, along with a good picture of where the drain plug is.
https://www.matthewsvolvosite.com/forums ... f=1&t=8767
It's a pretty easy procedure and you'll save a lot of money rather than taking it to a shop. Good luck!
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
A full flush can sometimes cause problems with transmissions with higher miles that have never been run with anything but the same fluid in there.
'98 S70 T5
volvomileage
- Year and Model:
+1 for drain and fill
does your oil smell burnt ?
i did the same, drain and fill 4 times over a 2 week period, (you should get about 3 to 3 liters and half out of the tranny drain plug) drain refill drive and so on the result is great almost all brand new oil...you will need a 22 mm box wrench to untighten the tranny drain plug..
as far as tranny oils you need dexron iii at oil, some use the mobil 1 syhtetic product with good results
i used the castrol dexron vi which is backward compatible and also semi syth and shifts are smooth...
at the same time you could service you power steering oil wich is also dexron iii if it wasnt serviced before...
volvo 850 95 sedan non/turbo 185 k
volvomileage
- Year and Model:
....for the power steering fluid i used a turkey baster to remove fluid from the p/s reservoir but leaving a bit in the resrvoir...added new fluid turned the wheels from one end to the other a few times , then removed again fluid being careful to leave a bit and topped up...if the fluid smells burnt its due also...
cheers !
cheers !
- 13 Replies
- 3969 Views
Last post by mrscullini
- 3149 Views
Last post by 850 LPT
- 26 Replies
- 5729 Views
Last post by Georgeandkira
- 10 Replies
- 2100 Views
Last post by MrGruffles
- 1752 Views
Last post by sacricide
