Fire trap, is it really that important to look after?
Thanks for that diagram. I have a little air compressor that I use for painting air brush (6 hp engine) would this enough to try blowing through the flame trap hole? What would I be looking for by doing that? Do I need to get the engine running?
06 V70
95 850 se
95 850 se
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
I thought you said yours was missing?
- misha
- Has thanked: 155 times
- Been thanked: 432 times
I think it would be smarter to pull it out and then clean it,if you don't want to change your oil after that.
If you do like it's explained in that diagram,you'll throw all of that gunk into oil pan.
Just pull it off,clean it and put it back...or just throw it away.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- misha
Strange....i thought he said that too.polskamafia mjl wrote:I thought you said yours was missing?
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
patrioty3k
- Year and Model: 1995 850 Turbo Wagon
Beating a dead post....does that apply to the '95 850 turbo?I am assuming I have to replace the pcv system? This 850's transmission was replaced 3 years ago...she pulled many a boat to Cape Cod....hopefully they did replace the rear main...I'm still getting slight oil leak and oil smell inside the car..don't know if the pcv was changed....my next project,along with the frt. struts....thanks...
1995 850 Turbo S/Wagon,Alpine head w/Sirius Sat. Radio--"OCTANE" power!
200K $400 Sleeper...nuff said!
The flame trap thing is not there but the housing that connects to the airbox hose is still there (empty housing) and the diagram provided suggests to blow a compressed air into it. Sorry if I didn't make it clear enough.polskamafia mjl wrote:I thought you said yours was missing?
And I was bit confused...I didn't realize that blowing the compressed air is to free the crude built up in the flame trap I thought it is to clear up clogged pcv system as the diagram suggested...right?
06 V70
95 850 se
95 850 se
