Important Information on Ecu issues (850,S70 series)
5sobs5
Year and Model:
Post by 5sobs5 »
Anybody. How do I remove that diagonal metal strap so I Can open the module box? :?
meteg
Year and Model: 2007 V70 2.0T
Post by meteg »
the diagonal metal strap is something we dont have in the european volvo models.I guess its only available in U.S market models. my car is a european version and has no metal strap on it.
note: the ecu's need no reprogramming after removal.. the only matter is you have to switch the ignition off and wait least 10 mins until all the power to the control modules are cut. and then remove the modules from the box.otherwise damage to the ecu modules is possible.
5sobs5
Year and Model:
Post by 5sobs5 »
Please. There must be somebody out there that can help me. I've already broken part of the support for the windshield fluid fill tube. Now in trying to force the metal strap off, I can see it slight crack just starting at the bottom of the box by the strap. I could really use someone insight and knowledge on how they opened their's. :o :cry:
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
No you don't.
I have swapped ECU's and it's an in and out deal even with the battery connected, no issues
Mr Vince
Year and Model: 1999 s70
Post by Mr Vince »
I would like to remove my ECU and Transmission control modules .can some one let me know the procedure ?
thanks Vince
Toplights
Year and Model: 1998 V70 20v Auto Cl
Post by Toplights »
My car is registered in the uk and did have a strap over the top of it, i removed mine with an angle grinder and great care.
1998 V70 2.5 Auto Classic.
1996 960 3.0 Auto "Hector"
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
meteg wrote:the diagonal metal strap is something we dont have in the european volvo models.I guess its only available in U.S market models. my car is a european version and has no metal strap
I have european model and i have that metal strap on top of ecu box.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
cread
Year and Model: 1996 850 Turbo
Post by cread »
so remove using instructions provided earlier and i can clean using electrical contact cleaner to clean deposits ?
bobsnow100
Year and Model:
Post by bobsnow100 »
You can get a big spray can of Electrical contact cleaner at Home Depot in the Electrical Department.
cread
Post by cread »
yeah i have a can, i wonder if the ECU is to blame for my issues, since replacing the starter I can turn the engine over but it never will start. Checked for spark and am not getting any. Changed plugs ,wires,cap,rotor and still no spark. I got a TPS code so I replaced that, replaced camshaft position switch, and ignition coil and still no spark HELP !!
