S40 2005 how do I replace the headlight lens cover
Someone backed into my vehicle, broke the right headlight lens cover. Can I just replace the lens. I did find a web page that sells aftermarket parts and they do sell a replacement lens with the seal, or as I've read on one post, does the whole unit have to be replaced.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Bill.
Did it give the year? As far as I know the separate glass and seal was only for 2004 and earlier. For the 2005 model year, which was introduced in late 2004, the complete headlight has to be replaced.I did find a web page that sells aftermarket parts and they do sell a replacement lens with the seal,
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
Glad to be of help but sorry to be the bearer of bad news in the extra cost.
Bill.
Bill.
Previously:
Previously:
Have you had to replace a headlamp? I was reading a post that gave step by step directions. There seems to be some screws that are hard to access. Is it something that someone with mechanical abilities can do? Or is it strictly a bodyshop job?
- billofdurham
Not on one of this age. I am still in the 20th century with my cars - 18th century with everything else, according to my grandchildren.Have you had to replace a headlamp?
However, the attached shows how it is done. No hidden screws, that was on the earlier model.
I have arrowed the locking plate as it took me some time to find it.
Bill.
Previously:
Previously:
Thanks Bill. However, one more question if you don't mind. I'm not sure I follow, it looks like you're describing changing the lens cover. I thought the whole headight assembly had to be changed. That other post referred to removing the whole assembly and moving out the bumper 2 cm to get the headlight out. Is that correct?
Thanks,
Glenn
Thanks,
Glenn
JDS60R
- Been thanked: 3 times
Glenn,
I miss Worcester.
Your light looks easier than the S70's - take a look.
Hope that helps.
I miss Worcester.
Hope that helps.
2005 S40 headlamp removal.pdf- (373.48 KiB) Downloaded 479 times
Retired
- billofdurham
Mine was the shortened version.
Moving the bumper was on the older model. When you pull the locking plate out the whole headlamp unit comes out. In JDS60R's longer version it shows that you have to remove the headlamp unit just to change the bulbs so, for once, Volvo has made it reasonably easy.
Bill.
Bill.
Previously:
Previously:
- 1259 Views
- 4929 Views
Last post by XC70Rider
- 1110 Views
Last post by mrbrian200
- 10 Replies
- 1802 Views
- 33 Replies
- 10994 Views
Last post by vtl
