xc70 rear wiper arm replacement Topic is solved
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
jfl2nd
- Year and Model: XC70 2005; 850 1996
Thanks for the pdf. My XC70, however, has the wiper arm going right, not left (and it is longer than the one in the diagram), and the nut is covered by a sort of shield that prevents one from removing the nut. I am assuming the arm must be prised off. -- Jimvegasjetskier wrote:
best to all, -- Jim Loucks
have an xc70, 2003. looking to understand how to remove rear wiper arm. nut is off, but not sure how to remove arm. doesn't pull easily. previously attached pdf just says to 'detach arm and blade' after removing nut. replacement part has no threads, so am assuming it's a pull. perhaps cut the old arm off? looking for advice please.
thanks
thanks
- Has thanked: 2858 times
- Been thanked: 1332 times
From Jim:
-- JimIt turns out that the cap covering the spray assembly pops off, and then you can simply back-off the nut. Much easier than I had thought. When placing the new arm on, you will need to be sure the new arm positions the wiper so as to stay on the glass at all times. These wiper arms are very fragile, so when I go to an automated carwash, I tape a piece of plastic over it (which I obtained by cutting down a plastic gallon milk bottle, and I use clear duct tape that leaves no residue of gray adhesive). Hope this helps.
Sorry in advance for bumping a 7 year old thread (!), but I just replaced the rear wiper arm on my 2002 V70 XC and this thread was very helpful!
Mine also wouldn't come off after removing the nut. Started in on it with the dremel after being unsuccessful wth WD40.. Before I made it even a 10th of the way through, the vibrations loosened it enough so I could remove it. Hurrah!
Photo attached if it helps anyone!
- 23 Replies
- 3270 Views
Last post by 850forum
- 738 Views
Last post by cvtech
- 1388 Views
Last post by CabezaDeVaca
- 1566 Views
Last post by erikv11
- 1902 Views
Last post by Vova585
