I bought a few weeks ago a V70 AWD with some headgasket issue (a minor leak). Before I bought it, previous owner drained the coolant. And as I wanted to drive the car to my trusted volvo mechanic, I wanted to top up the cooling system, just for the few ks. But I directly noticed everything was going down on the pavement. I located the leak at the turbocharger, but as I couldn't see exactly where it came from (and with the tought, the previous owner left some water without antifreeze in the turbo, and with the severe frost we had in Belgium, there might be a crack in it!), I started to work to get the turbocharger out. As I got the upper coolant pipe off, I saw this (see pictures). When I tried pouring off water where the coolant pipe fits in, the water came out from the hole just below...Isn't that hole supposed to be closed by a plug or? As I don't have a possibility to check on another turbo, and couldn't find any infos on vadis I want your opinion...Should be a plug in there? what size then? I don't want to take the turbocharger out if I can fix it this way...
Thanks guys!
