Anyone ever successfully extract a broken headbolt? Any tricks out there that would improve our chances of success.
Present plan:
Soak in Kroil for 2 days
Machine up some drill guides so we can accurately center on stud
Work our way up from 3/16 to 23/64" dia.
Use #5 1/4 easy out- we were leaning towards this somewhat oversized easy out due to expected required torque to entice stud to move
Tks GM
Broken Headbolt 1995 850 2.3L
I've done it with a Gator Easy out after soaking for a while and a gentle tap in the centre to free off any corrosion
Only ever had to drill a centre pilot hole reverse drilling with the Gator has always worked
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
renns
- Year and Model: 2005 XC70
- Has thanked: 3 times
- Been thanked: 6 times
If it broke flush or above the block surface, weld a hex nut to it, and unthread it. The thermal shock of welding the nut in place assists in releasing frozen threads, and you might find it comes out with little effort.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
