Help on 1995 850 GLT oil leak diagnosis
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Harmed? Nah. If the one you're talking about is the one right on top of the cylinder head there, it IS part of the PCV system, so you were correct in that. Change your oil...like, tomorrow or this weekend...if you haven't and everything'll be good.
'98 S70 T5
2016 Chevy Cruze Premier
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
As has been described, The 850's don't have a PCV Valve, they have a PCV "System" that is about as complicated as the space shuttle. Search through the repair database under PCV for more details. It really isn't that bad of a job except for one nut on the intake manifold that hides behind the alternator.
runpaulone
Year and Model: 850, 1995
Post by runpaulone »
Ozark Lee wrote:As has been described, The 850's don't have a PCV Valve, they have a PCV "System" that is about as complicated as the space shuttle. Search through the repair database under PCV for more details. It really isn't that bad of a job except for one nut on the intake manifold that hides behind the alternator.
I like how you say it's as complicated as a space shuttle, and then say it's one nut on the intake manifold. Ha! Oh wait, I see, except for that one nut!
Paul
1995 Volvo 850 GLT
Indiana
boosted5cyl
Post by boosted5cyl »
Well I did the warm motor/dipstick check yesterday, looks like I have some work to do, but at 186K, I cant complain. I left the dipstick a teeny weeny bit loose, I'd rather not have to do the rear crank seal or whatever blows out.
runpaulone
boosted5cyl wrote:I left the dipstick a teeny weeny bit loose, I'd rather not have to do the rear crank seal or whatever blows out.
Is this ok to do, and will it blow oil out of the dipstick hole while driving? I'm considering doing this, frankly because I don't want to do all the PCV work since my car is old with high-mileage as well. I seem to have lost a considerable amount of oil since my last oil change (a quart or so in 600mi.).
Paul
1995 Volvo 850 GLT
Indiana
jblackburn
I tried that for about a 40 mile drive when my PCV system was clogged, and it blew a bit of oil all over my engine, and I definitely smelled fumes from it while stopped. Then again, I did floor it to pass a truck climbing up a mountain at 15 mph. If you don't do that, I suspect you'll be ok :wink:
'98 S70 T5
