Did you know? 🤔
Amazon Link
Buy your stuff using this and it helps MVS!
440 1.8i auto misses and cuts out when warm
- Year and Model: 440 1995
- Has thanked: 0
- Been thanked: 0
Please can someone tell me what's causing the following problem with my 440?
My 440 1.8i automatic is fine when cold but when it warms up it misfires and cuts out to the point where it will not restart until the engine is cold again.
It has new plugs and leads and I also changed the coil pack for a used coil pack.
The RAC diagnosed overfueling and random loss of spark across all cylinders and referred me to a local volvo specialist garage. This garage diagnosed a faulty single point fuel injection unit.
I've just changed the fuel injection / carb unit for a used unit and still have the same symptoms.
I tried unplugging the electrics connection to the idle control motor and it just revs higher but still misses.
- billofdurham
- Year and Model: 855, 1995
- Has thanked: 0
- Been thanked: 3 times
Re: 440 1.8i auto misses and cuts out when warm
Have you checked for fault codes using the On-Board Diagnostic (OBD) Unit in the engine bay? This is a first step to diagnosing problems.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- Has thanked: 0
- Been thanked: 0
Only getting code 111 (no fault found).
The garage disconnected the battery to reset the fault memory and I've driven it around until it gets hot, misses and cuts out to see if it generates an error code and still only getting code 111.
- billofdurham
- Has thanked: 0
Back to basics. The attached has things to check for both conditions.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
Do you know how I can check the ignition / coil circuit other than replacing the coil pack? Thanks
- billofdurham
- Has thanked: 0
It can be done with an ohmmeter or multimeter:
If you also need the instructions for checking the ignition amplifier, post back.
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
Please will you post the instructions for checking the ignition amplifier. Many thanks
- billofdurham
- Has thanked: 0
No problem:
Bill.
Bill.
Previously:
Previously:
- Has thanked: 0
- Been thanked: 0
Many thanks Bill.
The good news is my 440 appears to be well again
Worked through the list and tests and didn't find any faults. Did clean the electrical contacts and add injector cleaner to the fuel and its driving around nicely.
The only thing I've noticed is sometimes the temperature guage does not appear to work, with the needle stuck at the bottom as though the ignition is off, but the cooling fan still worked / turned on and off.
The diagnosis module still says 111 (no fault found).
- billofdurham
- Has thanked: 0
Thank you for the update.
The temp gauge problem could be a bad connection at the sensor or it could be the sensor starting to fail.
You can check the sensor by removing the plug and checking across the two terminals with an ohmmeter.
Water temperature at 0C 5,800 ohms.
At 20C 2,500 ohms.
At 80C 330 ohms.
Bill.
At 20C 2,500 ohms.
At 80C 330 ohms.
Bill.
Previously:
Previously:
2002 S40 cuts out at high RPM and flashes check engine light.
by Grant02S40 » Sat Nov 19, 2016 2:07 pm » in Volvo S40 & V40 Forum 2000-2004 - 2 Replies
- 870 Views
Last post by cbburtraw
Thu Dec 01, 2016 4:44 pm
Cold Start ok, almost stall during warm up, then fine when warm
by pdr1966sc » Wed Dec 19, 2018 4:59 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 0 Replies
- 76 Views
Last post by pdr1966sc
2007 xc 70 cruise cuts out
by raquette » Fri Dec 18, 2015 8:42 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 1 Replies
- 400 Views
Last post by xHeart
Mon Dec 28, 2015 9:36 am
2002 S60 2.4T Engine cuts out
by philthevolvo » Wed Dec 28, 2016 8:24 pm » in Volvo V70 & XC-70 2001-2007, S60 2001-2009 - 3 Replies
- 367 Views
Last post by philthevolvo
Thu Dec 29, 2016 6:05 pm
