I have a noise that sounds like a card in a bicycle tire...its a rubbing/ticking from the front passenger tire...it goes faster as I increase speed and eventually quiets a little.
Could it possibly be the front brake pads rubbing???(they are in need of changing)
I did have the car inspected two months ago and it had to have a new rack and pinion on the drivers side and a control arm on the passenger side.
Any ideas on what to check for would be great, Im not good at identifying issues with suspension.
Ticking noise from front passenger tire
daddysvolvobus
- Year and Model: v70 xc awd 1999
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Check to see if you have a nail or a screw in the tread of the tire.
very well could be a nail, but also could be a cv shaft. also check the tires, a "feathered" tire will produce some noise. also a "cupped" tire. With that said, your alignment would be responsible for tire wearing issues.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The thoughts that come to my mind are:
1) Warped rotors grabbing. Do your brakes shake badly when applied? If not, ignore this one.
2) CV joint
3) Bearing
Honestly, the best thing to do would be to jack up that side of the car, put it in Neutral...make sure your parking brake is set...yes, I have made that mistake before
...and spin the wheel and see what, if anything is catching or making a noise.
2) CV joint
3) Bearing
'98 S70 T5
2016 Chevy Cruze Premier
- kcodyjr
- Year and Model: 2006 S60 2.5T AWD
- Has thanked: 17 times
- Been thanked: 23 times
Also check for:
* fender liner sagging
* pebble caught between the tire treads
* steelies & wheel caps? debris inside it?
- Kevin
- Kevin
5 others that came and went
- 1055 Views
Last post by bluebossa
- 4012 Views
Last post by Klausc
- 1007 Views
Last post by darrylrobert
- 1035 Views
- 16 Replies
- 2062 Views
Last post by Camaro737
