S80 popping noise in front left
Dealer told me my sub frame bolts and orings need to be replaced. They said this was what was causing my popping creeching noise in the front left. They will have it done tommorow, I hope this does fix it. This is an FYI for all of you that have replaced everything on the front, struts, plates, bushings, etc. and still have a noise!!
Chapstick
Sorry, I forgot about those rubber bushings (go between the engine cradle and the chassis). Those are a real bear to swap out--they will have to lower the cradle (engine and transmission support) and wedge those suckers in. I hope that does do it, Mikey!
Just to clarify. They are not really replacing anything, yet they are a special kind of oring made by Volvo just for this kind of problem. They said you couldn't buy these anywhere else because it was just created to cure the subframe noises.Chapstick wrote:Sorry, I forgot about those rubber bushings (go between the engine cradle and the chassis). Those are a real bear to swap out--they will have to lower the cradle (engine and transmission support) and wedge those suckers in. I hope that does do it, Mikey!
Chapstick
Design flaw??? That's their fix for the noise? Sorta like adding inserts to your shoes to make you taller. It's no wonder Volvo is catching hell on the S80s. And why you'll never see anything beyond a 5-cylinder in one. Make sure you blast the SM for this "proprietary" fix that is costing you $/time/peace of mind. Just my .02.
I just got my car back and low and behold that is exactly what they put on the back two subframe bushings was a 3/8" thing oring right on top of the bushings. Guess how much for 2 orings and 2 bolts?? $358 !!!!!!Chapstick wrote:Design flaw??? That's their fix for the noise? Sorta like adding inserts to your shoes to make you taller. It's no wonder Volvo is catching hell on the S80s. And why you'll never see anything beyond a 5-cylinder in one. Make sure you blast the SM for this "proprietary" fix that is costing you $/time/peace of mind. Just my .02.
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
Attached are a couple files. One gives part numbers. The other gives procedure.
o ring cure for subframe knocking noise.pdf- (134.27 KiB) Downloaded 1204 times
o ring cure for subframe noise part numbers.pdf- (31.47 KiB) Downloaded 1312 times
OEMVolvoParts
- Year and Model: ALL
Part number 8638585 is for the O-ring. You need two for the subframe.
- 1432 Views
Last post by oragex
- 1569 Views
Last post by chris11211
- 555 Views
Last post by GlennG2759
- 11 Replies
- 3532 Views
Last post by hunterhuni
- 2681 Views
Last post by SuperHerman
