440 1.8i auto misses and cuts out when warm
Discussion and advice for 440, 460, 480 owners.
1986 - 1997 440
1986 - 1997 460
1986 - 1997 480
marct
Year and Model: 440 1995
Post by marct »
Please can someone tell me what's causing the following problem with my 440?
My 440 1.8i automatic is fine when cold but when it warms up it misfires and cuts out to the point where it will not restart until the engine is cold again.
It has new plugs and leads and I also changed the coil pack for a used coil pack.
The RAC diagnosed overfueling and random loss of spark across all cylinders and referred me to a local volvo specialist garage. This garage diagnosed a faulty single point fuel injection unit.
I've just changed the fuel injection / carb unit for a used unit and still have the same symptoms.
I tried unplugging the electrics connection to the idle control motor and it just revs higher but still misses.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Have you checked for fault codes using the On-Board Diagnostic (OBD) Unit in the engine bay? This is a first step to diagnosing problems.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
marct
Post by marct »
Only getting code 111 (no fault found).
The garage disconnected the battery to reset the fault memory and I've driven it around until it gets hot, misses and cuts out to see if it generates an error code and still only getting code 111.
billofdurham
Back to basics. The attached has things to check for both conditions.
440 engine hard start.pdf
(39.95 KiB) Downloaded 536 times
Bill.
Previously:
marct
Post by marct »
Do you know how I can check the ignition / coil circuit other than replacing the coil pack? Thanks
billofdurham
It can be done with an ohmmeter or multimeter:
440 ignition coil check.pdf
(74.54 KiB) Downloaded 413 times
If you also need the instructions for checking the ignition amplifier, post back.
Bill.
Previously:
marct
Post by marct »
Please will you post the instructions for checking the ignition amplifier. Many thanks
billofdurham
No problem:
440 ignition amplifier check.pdf
(288.19 KiB) Downloaded 387 times
Bill.
Previously:
marct
Post by marct »
Many thanks Bill.
The good news is my 440 appears to be well again
Worked through the list and tests and didn't find any faults. Did clean the electrical contacts and add injector cleaner to the fuel and its driving around nicely.
The only thing I've noticed is sometimes the temperature guage does not appear to work, with the needle stuck at the bottom as though the ignition is off, but the cooling fan still worked / turned on and off.
The diagnosis module still says 111 (no fault found).
billofdurham
Thank you for the update.
The temp gauge problem could be a bad connection at the sensor or it could be the sensor starting to fail.
You can check the sensor by removing the plug and checking across the two terminals with an ohmmeter.
Water temperature at 0C 5,800 ohms.
At 20C 2,500 ohms.
At 80C 330 ohms.
Bill.
Previously:
