Erratic shifting
VolvoFreak
- Year and Model:
Erratic shifting
Doesn't happen all the time, in fact, it's uncommon, but every so often in my '93 GLT my tranny shifts "funny". For instance, last time it happened, I was going down a long hill and it shifted out of overdrive like it was engine braking. Another time I was in the city and it seemed to slip between 3rd and overdrive a touch - thats happened 2 or 3 times. Also, a couple of times while going up hill, it shifted out of overdrive like it should have, but didn't shift back in even if I took my foot of the gas. No codes are shown and fluid looks and smells perfectly fine.
1993 850glt
219,000+ miles and counting
- Has thanked: 2660 times
- Been thanked: 1254 times
Fluid level checked? Remember to check while car is idling, warm, on level surface.
VolvoFreak
- Year and Model:
According to my mechanic, the fluid level and quality was fine (I should check myself though). Actually, the tranny was power flushed about 5k miles ago...matthew1 wrote:Fluid level checked? Remember to check while car is idling, warm, on level surface.
1993 850glt
Guest
"...I was going down a long hill and it shifted out of overdrive like it was engine braking."
I've always considered that normal (by design).
VolvoFreak
- Year and Model:
It very well may be normal operation.. The only other Volvo I've ever owned was an '88 240dl. That's one reason I posted, to see if it was normal. I mean, as far as front-wheel drive vehicles, the only one's I've owned were an '84 Pontiac Sunbird and '86 Olds Delta 88 which never did that. Everything else have been rear-wheel drives and I've only had my 850 for about 4 months.Guest wrote:"...I was going down a long hill and it shifted out of overdrive like it was engine braking."
1993 850glt
- 731 Views
Last post by jimmy57
- 714 Views
Last post by mwhexplorer
