Rear Brake Shims
Ironbutt1345
- Year and Model:
Are the rear brake shims available from auto parts stores or only from Volvo? My rear brakes squeal, and the brakes were replaced right before I bought the car. I bought some of the "goop" you put on the pads, and it helped a little but not much.
T.J., 1997 850 GLT
White850Turbo
- Year and Model:
You may be able to get Autozone to special order something like that, but I would highly recommend going with the OEM Volvo shims. They're around $5 each even at the dealer. The part number you'll want is 1359772. Make sure upon reassembly that you use plenty of the anti-squeal grease all over the backing plate also.
-Sean
1995 850 Turbo (Extensively Modded)
1998 S70 T5 (Almost Stock)
- Has thanked: 2864 times
- Been thanked: 1332 times
Ironbutt1345
- Year and Model:
Thanks, I'll try that.
T.J., 1997 850 GLT
