narrowband wire hook up
phils94850
Year and Model: 2009 s60 turbo
Post by phils94850 »
im in the process of hooking up a pillar mounted boost and narrowband gauges.
can someone tell me which wire and where do i hook up my narrowband to get the signal from the O2 sensor ? Where is the easiest place to access the wire ? a pic would be great !! thanks for any help...
1996 Platinum Edition
atefitty
Year and Model: 850R 1997
Post by atefitty »
You can't..you have to get another bung put into your downpipe and use the signal from an o2 sensor that will give you a voltage reading ranging from 0 to 1 volts...I used a leftover one from my old Isuzu pickup..
I really don't recommend doing a narrow band, spend the money and get a wideband.
phils94850
ate... i had a narrowband hooked up to my other 850t i had and it worked fine. I just dont remember how i did it. Its been a few moons ago. I know narrows arent popular, but, thats all i can afford right now...
atefitty
Post by atefitty »
phils94850 wrote:ate... i had a narrowband hooked up to my other 850t i had and it worked fine. I just dont remember how i did it. Its been a few moons ago. I know narrows arent popular, but, thats all i can afford right now...
Okay listen. If you hook a ohmeter to the signal wire on your o2 you will see that your sensor operates on a 1.0-1.5 volt signal...if you hook your guage to it, you will be rich all the time..the guage works on a 0-1v signal...so I'm just telling you what I just went through.
