98 S70 T5
The oil leak has been around for some time now but has all of the sudden decided to get worse. At first it was just a thin film on the bell housing (BH) next it moved in size to a few drips on the drive. But in the last 2 weeks it has grown more than can be ignored.
First glance, I thought it was the RMS but the more I investigate it appears to be leaking from the oil pan. I say this because the oil is not coming from the weep hole at the bottom of the BH but from the seam at which the BH connects to the pan. In addition to that, the flex plate as seen in pic is not oil soaked as it would be if coming from RMS. To be more specific, rear-left-upper corner of the oil pan, right above trans drain bolt. See attached pics, notice oil droplet at oil pan/BH seam.
The question is: How involved is the removal of the oil pan? From what I see, it looks like I would have to remove -
1. Pan Bolts
2. Oil cooler lines
3. Power steering lines
, and the pan should come out. Or is there more to it, that I am not seeing?
Thanks
TOM G
Oil leak
Oil leak
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
You are right about removing the pan. I think there was a thread or a write up about that but I can't remember. I remember the person saying they bent the power steering lines out of the way. I've always wondered what that would look like. If you do decide to remove the pan would you be able to take some pictures and make a write up? That would be really appreciated.
Joe Hurless
- Year and Model: e36 328is
Looks like its coming from the rear main
- tom39
- Year and Model: 2011 S80
polskamafia mjl, will do on pics.
So, do you believe my assumption is right that the leak is is the oil pan or is joe saying what I don't want to hear and I am trying to find another reasons other than RMS?
TOM G.
TOM G.
11 - S80 Silver 132k/mi
iselloil
- Year and Model: 1999 V70 XC AWD
Check the cam seals,it will run down the back of the motor and looks like a rear main leaking.
1999 V70 XC
1999 V70 under constuction,or
destruction from previous owner
Mobil 1
K & N Filters
Ceramic brakes
Mobil 1
K & N Filters
Ceramic brakes
- tom39
Does anyone know if the oil pan is sealed by a gasket or with a sealant. Can't find a gasket on IPD or FCP Groton for the pan just some oil passage o-rings and gasket sealant.
Thanks
TOM G
Thanks
TOM G
- Year and Model: Many Volvos
- Been thanked: 76 times
+1 on what cattledog said. Get the OEM Volvo pink stuff, the Kiril K2 sealer doesn't work worth beans.
Don't use RTV, it will squish out and clog the oil pump intake strainer.
I have been workind on the td1 5 cylinder version and have just replaced both the main oil seals. ther is no gasket seal on the sump pan it is sealant as said by our other friends.
Your problem will be to replace the seals you will have to dump the gearbox /clutch and flywheel to get access then if you are lucky it will be a press in seal around the main rear crank uk £8. My TDi took me a week to find the right seal and it is bonded in to a plate and was only available from VOLVO (groan) UK £140! for goodness sake.
Good luck but be prepared for a big rebuild. on the positive side at lease the seal is behind the fly wheel and your clutch should be ok from contamination.
