Emergency jack + jack stands? 2000 V70
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
I don't have a floor jack, but want to raise my 2000 V70 front end up on floor jacks. Can this be safely done using only the emergency jack? The following plan does not seem safe:
1. Use the emergency jack to raise the driver's side.
2. Place the jack stand under the proper front support.
3. Lower and remove the emergency jack, hopefully dropping the rear driver's wheel back onto the ground... but lifting the front passenger's side?
4. Use the emergency jack to raise the passenger's side.
5. Place the jack stand under the proper front support.
6. Lower and remove the emergency jack.
Will this process work to raise either the front or the rear? Or must I buy a floor jack? Is there a lesser alternative to a floor jack, since I'll rarely be using it and don't need all that power?
Thanks.
FireFox31
ttermyna
Year and Model: 1999 V70
Post by ttermyna »
bottle jack? they don't take up that much space, in fact you could probably stow it in the spare wheel well. also a bit cheaper.
larryh
Year and Model:
Post by larryh »
those jacks that come with the car are so sketchy :shock:
Harbor freight has floor jacks for really cheap. of course they are really cheap so you'll be lucky to get three uses before it craps out on you. but i use one.. and keep taking it back and exchanging it when it quits working. someday i'll get a decent one because it's frustrating using cheap throw away junk .
wheelsup
Year and Model:
Has thanked: 16 times
Been thanked: 22 times
Post by wheelsup »
I bought a set of jack stands and jack @ wal-mart for $30 a few years ago. It's not one of those "racing jacks" so it takes awhile to get up but for the $$ it was worth it. I've used it many, many times and so far so good. Even though you think you won't use it you probably will, spend a little $$ and get one IMO. Those emergency jacks aren't called widow makers for nothin'.
1995 850 GLT Wagon w/ 200,000 miles
Pauloil
Year and Model:
Post by Pauloil »
anyway u can get car up on jack stands is ok. ramps are nice!
when my car is on these I also put tire under car frame and a brick behind a rear wheel
99 V70XC 158K
95 850glt 188K
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
Pauloil wrote:when my car is on these I also put tire under car frame and a brick behind a rear wheel
+1
My lazy way is to put a piece of 2x4 under the sub frame and jack (under the 2x4) the front up then get the stands in.
http://volvospeed.com/Repair/jackingpoints.php
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
