I don't have a floor jack, but want to raise my 2000 V70 front end up on floor jacks. Can this be safely done using only the emergency jack? The following plan does not seem safe:
1. Use the emergency jack to raise the driver's side.
2. Place the jack stand under the proper front support.
3. Lower and remove the emergency jack, hopefully dropping the rear driver's wheel back onto the ground... but lifting the front passenger's side?
4. Use the emergency jack to raise the passenger's side.
5. Place the jack stand under the proper front support.
6. Lower and remove the emergency jack.
Will this process work to raise either the front or the rear? Or must I buy a floor jack? Is there a lesser alternative to a floor jack, since I'll rarely be using it and don't need all that power?
Thanks.
Emergency jack + jack stands? 2000 V70
- FireFox31
- Has thanked: 159 times
- Been thanked: 303 times
FireFox31
those jacks that come with the car are so sketchy
Harbor freight has floor jacks for really cheap. of course they are really cheap so you'll be lucky to get three uses before it craps out on you. but i use one.. and keep taking it back and exchanging it when it quits working. someday i'll get a decent one because it's frustrating using cheap throw away junk .
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
I bought a set of jack stands and jack @ wal-mart for $30 a few years ago. It's not one of those "racing jacks" so it takes awhile to get up but for the $$ it was worth it. I've used it many, many times and so far so good. Even though you think you won't use it you probably will, spend a little $$ and get one IMO. Those emergency jacks aren't called widow makers for nothin'.
1995 850 GLT Wagon w/ 200,000 miles
confused_al
- Year and Model: 1996 TLA wagon
+1Pauloil wrote:when my car is on these I also put tire under car frame and a brick behind a rear wheel
My lazy way is to put a piece of 2x4 under the sub frame and jack (under the 2x4) the front up then get the stands in.
http://volvospeed.com/Repair/jackingpoints.php
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- 18 Replies
- 2693 Views
Last post by ducksaysquack
- 20 Replies
- 2588 Views
Last post by j-dawg
- 881 Views
Last post by Anthari
- 756 Views
Last post by paredown
- 188 Views
Last post by STLV70
