V70 2004 rumbling or rubbing in front
PatrickEsq
- Year and Model: Volvo 2004
Sometimes it sounds like something is rubbing, when moving slowly with wheels turned; this has just developed. This vehicle is in excellent shape, about 48,000 miles, dealer maintained and garage kept. What could the noise be?
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
Hello, With wheels turnED or while turnING the steering wheel? Have you strayed from factory sized tires? Visually check for a loose fender liner or "polished" zones. Have a friend walk beside your car when you duplicate the noise. If you've turned the steering wheel to lock (fully to one side or the other), ease up a bit. Raise the front end and turn the wheels with the weight removed. Turn each raised front wheel and listen. Get back to us. Kira
PatrickEsq
Georgeandkira: Thank you for the tips. When the weather clears up here, we will follow your suggestions and let you know. -Patrick
