maintainence at 162,000
panda
Year and Model: 1998
Post by panda »
i am having the timong belt and serpentine belt replaced at 162000.
Is there anything else besides the obvious air filter that should be at this mileage/
thanks
how about transmision fluid?
thanks in advance
panda
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
You are about 20k late on the timing belt but better later than never. This is the change that hurts the wallet - you really need to change everything in the timing belt chain. Along with the belt you should change the tensioner, the tensioner roller, the idler roller and in my case I go ahead and change the water pump which is driven off of the timing belt. The water pump is a source of great debate but I have had two of them that were in the process of destroying themselves at the 140 K interval but then again I had an original that was just fine at 210K - I replaced it anyway.
The rule of thumb is that you change out everything on every other timing belt change. Your first belt change should have been at around 70 k miles.
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
everythig Lee said and also the tranny fluid.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
