1999 V70R AWD
Hello crew. Doing a search I see that this problem has been posted before by others with no posted solution. So I'm posting it again, maybe somebody has since figured it out.
Back around Christmas I replaced my front struts and mounts with OEM parts. The job went super easy once I got large enough compressors, and the car was quiet and smooth after that. I waited about a month to get new tires and alignment done. As soon as I got in the car at the shop the passenger side started making a creaking/moaning noise. Pretty sure it's the strut mount. Power steering, joints and ends, wheel stops, cv joints, all good. It happens worst when turning steering while standing still. If I put my hand on the mount I can feel the vibration, like maybe the bearing up there is binding up. The struts and mounts are new, and look to be intact. What could an alignment have done to cause this? I really don't want to take everything apart, and have to waste another $100 an another wheel alignment.
P.S. it also only happens sporatically often.....these parts were bought on ebay.
Creaking/moaning Strut Mount
KEWROCK
- Year and Model: V70R 1999
OK, doing a further Google search, this problem seems to be quit common on all makes of cars. Apparently someone has a patent to correct it, But I do not understand what the hell I'm reading.
Here's the patent link....... http://www.patentstorm.us/patents/61261 ... ption.html
Anybody with with a little more synaptic activity than me want to take a crack at it, and maybe translate?
1999 V70R T5 AWD Red
- Year and Model: Many Volvos
- Been thanked: 76 times
The good news is that if it is the bearing you can just replace it and normally you don't need to mess with another alignment. You also don't need to use the spring compressor again - it is all done from the top. Don't buy the junk Scan Tech replacements. As painful as the OEM price is go ahead and buy OEM. DW Volvo should give you a decent price on it/them.
Have you tried greasing the steering stops on the control arms? They can cause the creaking and groaning that you describe.
KEWROCK
How do I get it out from the top? The whole assy has to come completely out of the car to split the bearing from the spring seat?
I don't remember, but is there any alignment adjs where the assy bolts to the spindle? or at the top of the tower.
Thanks
Thanks
I have changed them out by removing the top strut nut and the inverted castle washer on the top and by removing the two bolts on the control arms where they bolt up to the frame so as to drop the strut assembly far enough away that I could get strut mount out of the strut tower. I also removed the ABS sensor wire.
The spring seat just rests into the strut mount / bearing.
- 543 Views
Last post by Doc67
- 2562 Views
Last post by dono
- 972 Views
Last post by GreenMagicMan
- 1437 Views
Last post by pmc2411
- 1192 Views
Last post by whatgoeson
