V70 2001 Engine system service required Code 44 just came up
what does codee 44 stand for?
JRL
- Year and Model: Several
- Been thanked: 16 times
Never heard of a code 44, it means bring it to a Volvo dealer
Gloworm03
- Year and Model: '00 S80 2.9
My S80 read the same message yesterday, It scared me when it came on! It was running fine, the second time i turned the car on today and the light shut off and the message is gone. Im not sure what it means but hoping it is a fluke......the odd part is intermittantly for the last few days my check brake light has come on everytime I have someone look they are all working properly & the check brake light isnt on, im not sure if they are related but the only thing ive noticed.....
2001VolvoXC70
- Year and Model: XC70 2001
Did u ever find out what code 44 meant??
They've done studies you know. 60% of the time I work, every time!
Fish stick88
- Year and Model: 1994 - 850 Sedan
44 is not a trouble code. The message "Engine System Service Required" is not a maintenance reminder and the trip button is not the procedure to reset it. The only message that can be reset with the trip button is the service reminder ("Service" light on some models, "Time for Regular Maintenance " message on others).
Volvo does not give us info on what "44" means. sometimes its hidden holding other problems inside
(Another Volvo Forum)
Aj
Hope that helps... Sounds kinda sketchy...
Aj
Speed has never killed anyone, suddenly becoming stationary... That's what gets you.
'94 850 Sedan - 160k miles
2001VolvoXC70
Thanks. It does help a bit, im trying to find out what engine system service I need. My obd2 is not giving me anything perhaps it is the faulty ETM that was recently discovered.
Fish stick88
have you tried disconnecting the battery for a bit?
Remember to keep track of your radio station programs and settings ig you do so... you'll have to reset them later.
2001VolvoXC70
Ive disconnect my battery and the message "Engine System service required" disappeared. However it reappeared on the first driving cycle. Im thinking it may be related to the ETM failure.
Fish stick88
https://www.matthewsvolvosite.com/tag/volvo-etm
Hope that helps i didnt look too much into detail, im not expert with the XC70
- 4666 Views
- 1946 Views
Last post by psamanni
- 11 Replies
- 6413 Views
Last post by naperboiler
- 25 Replies
- 18610 Views
Last post by ADriggs26
- 902 Views
