S-80 1999 How to remove and replace a fuel pump?
retsyor
Year and Model: 1999 S-80 T6
Post by retsyor »
How to remove and replace a fuel pump on a 1999 S-80?
volvomileage
Year and Model:
Post by volvomileage »
hello,
i have never tried the pump removal on a s80 but here goes this pdf should help
fuel pump.pdf
(2.66 MiB) Downloaded 2180 times
volvo 850 95 sedan non/turbo 185 k
frankie088
Year and Model: 1999 S80 T6 2.8L
Post by frankie088 »
Was just wondering if you had replaced the fuel pump already and if you have any other advice, links, tips to offer? Also, I believe the access is under the back seat but are there any links/pdfs that show this process? By the way, if anyone can respond right away it would be GREATLY appreciated - been stranded since 12/2, just my daughter and I, replaced the filter yesterday, checked all fuses, etc, still no fuel pressure from the valve. Finally located a pump but my brother is having to bring it from 160 miles away as there was none nearby - he's on his way now so I need some info quick! Thanks! Lynelle
dcarlson12
Year and Model: 1997 850 T5
Post by dcarlson12 »
The following files tell how to get to the fuel pump i.e. rear seat removeal...
The side cushion is a bear to remove. You have to release the 'spring clip' from the lower clip. To do this you have to reach under and with a strong finger push the center spring clip upward and then left the cuhsion backward/upward to the rear.
rear seat assembly removeal.pdf
(20.75 KiB) Downloaded 939 times
rear seat cushion removeal.pdf
(47.12 KiB) Downloaded 800 times
rear side cushion removeal.pdf
(41.08 KiB) Downloaded 931 times
rear seat back rest removea.pdf
(39.75 KiB) Downloaded 1122 times
cmatwie99
Year and Model: 2001 Volvo s60 t5
Post by cmatwie99 »
once you remove the seat is the fuel pump easily accesseble?
Rougesvp
Year and Model: S80 T6 '99
Post by Rougesvp »
Yes, there is a nipple on top of the fuel tank also... this may be the source of the 'leak/fuel smell'. Check it before you get stuck into the pump!
If fuel is leaking from the nipple, two choices, try and seal it or replace the tank.
Good luck!
Pault
Year and Model: 2000 Volvo S80
Post by Pault »
Is the fuel on a 2000 Volvo S80 under the rear seat?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
Yes
s80 fuel pump.jpg (151.5 KiB) Viewed 5011 times
Also -> Amazon link
ndphotonl
Year and Model: 2001 S80 2.4T
Has thanked: 27 times
Been thanked: 33 times
Post by ndphotonl »
My 2001 S80 2.4T did not have this seat frame, this video should help you. I bought the special tool to get the ring of, makes it way easier. Its fairly straightforward.
ImageVolvo S80 2.4T Replacing the Fuel Pump by Andy Ramdin, on Flickr
Volvo S80 2.4T Wasa Limited Edition (+-230-240BHP)
FlickR images
