Difference between High pressure and low pressure Turbo
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Today took my car to the local Volvo specialist who told me that my car may not be a 225bhp T-5 as it's not boosting as it should, I've been saying that for a while, it was mentioned there were several versions of the T-5 variant one with high pressure rest with low pressure they suggested I contact my Volvo agent for them to check via my vin code
Can anyone tell me how my Vin code decodes HPT or LPT ?
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
wooz797
Year and Model: 97 850
Post by wooz797 »
tour vin number will tell which engine you have the 6th and 7th digit for us and canada
7th and 8th for "others" thats what my book is showing. It should be 53 or 51 i cant recall which is the high pressure
JDS60R
Been thanked: 3 times
Post by JDS60R »
51 - LPT -Low pressure turbo
52 - CHPT - R model only - Crazy High Pressure Turbo ( That's a joke. Did you see what I did there? - With the "Crazy" part)
53 - HPT - High Pressure Turbo
Retired
charlyW
Post by charlyW »
except from Vin code really makes things interesting
YV1 LW 57 06 V 2
57 is Turbo Variant B5254T not the 2.3 T-5 on Timing case says B5234T
06 is AW50-41 Auto
V is 1997
2 is Belgium
Engine code 911359
assorted numbers 68215 523/ 04
ECU Assorted Numbers
GA2
Coo1
T96166124
0261203852
PO9125330
IT2654585
charlyW
Post by charlyW »
Must ad my Car is a an English model
ECU is bosch for the EFI and Aisin for the Autobox [at least thats ok]
JDS60R
Post by JDS60R »
Coming back as YV1LW5706V2911359 has invalid check number
Is that your VIN?
Retired
charlyW
Post by charlyW »
No my complete Vin is
YV1LW5706V2339341
I think the confusion has been resolved from the official either US or UK Service manual parts, see added PDF, 57 is the UK 2.3 Turbo engine 55 would be a 2.5 Turbo
MaintenanceInfo.pdf
(419.57 KiB) Downloaded 1226 times
JDS60R
Post by JDS60R »
1997
Volvo
850
B5234FT
AW50-42
Is it left or right hand drive ?
Is it a wagon or a sedan? - It keeps saying wagon
Retired
charlyW
Post by charlyW »
my 855 is a RHD Estate you call that an wagon
JDS60R
Post by JDS60R »
B5234FT 5 cylinder, 2.3L, 4 valves per cylinder, turbo, Motronic ECU (Engine Control Unit) controlled from 225 hp (166 kW)
Retired
