trans swap 98 S70 to 93 850
Anyone know if the trans from a 98 S70 will work in a 93 850? I know the trans will physically fit, since its the same engine and all, but will I have to change the axels or any other of the steering/front suspension gear? I'm assuming I will also need the TCM from the S70. I can get a trans from the local pull a part for cheap, and it would be really nice to have a 5 speed.
93 850 GLT sedan 156K
94 850 Turbo 189K
94 850 Turbo 189K
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Is the S70 transmission that you want to get a 5-speed? That would work absolutely no problem, and you'll just remove the TCU entirely from your car. Make sure to get all the hydraulics while you're at it
If it's an auto, the transmission will fit no problem, but the problem will be getting the S70's TCU to talk to the ECU in your 850. From a wiring standpoint, it won't.
'98 S70 T5
2016 Chevy Cruze Premier
i thought the auto for the 98 S70 was a 5 speed, LOL. if I get the TCU, will it just throw the CEL(I can live with that) or will it cause more dire problems? If I do a swap, I want to get the best possible trans that will fit in my car. Hate to replace it and have it go bad in a few months to a year.
94 850 Turbo 189K
94 850 Turbo 189K
jblackburn
Oh, gotcha. No, the transmissions are the same 4-speed until the 2000 (base) model S/V70. However, the wiring in the 96-98 models is different. I think the swap CAN be done, but the speed sensor is different on the earlier models, so it will flip out not knowing the right shift points.
I'll try to look at some things and get back to you. I'm sure they can be retrofitted to work. The straight swap, though, would be to get one from a 93-95 model.
'98 S70 T5
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
IIRC you have to wire in the wheel speed sensor from the ABS to the transmission sensor. I think that was what was done. Since the speed sensor is just electrical impulses it takes it fine.
1995 850 GLT Wagon w/ 200,000 miles
Sean-E-Boy
- Year and Model: 1995 850 2.3T Wagon
Would love to bring this topic back up. Anyone done it? What about the 5 speed auto into the 850?
Have been looking for ways to bring up the mpg, seems like this would help.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
5 speed is a no go. It has a TCM that needs CAN inputs from ECM and ABS that do not exist on pre-99 cars.
96-98 are interchangeable and 93-95 are too. 93-95 has speed sensor on final drive case that is not fitted on the 96-98.
- 1311 Views
Last post by yeti man
- 11 Replies
- 1903 Views
Last post by beigg
- 17 Replies
- 7851 Views
Last post by beigg
- 967 Views
Last post by Craigd2599
- 1436 Views
Last post by FLXC90
