Hello all, I ve got a 2000 v70 Classic - the orange arrow which shows up when you use W or the lower gears is constantly flashing, any ideas?
Thanks
V70 Classic auto box light
Guest
Guess not thenAnonymous wrote:Hello all, I ve got a 2000 v70 Classic - the orange arrow which shows up when you use W or the lower gears is constantly flashing, any ideas?
Thanks
- Has thanked: 2660 times
- Been thanked: 1255 times
You need to have your code(s) read. This talks about it:
https://www.matthewsvolvosite.com/chat/p ... ight=codes
Guest
Cheers Matt, what is so "dreaded" of the flashing arrow????matthew1 wrote:You need to have your code(s) read. This talks about it:
the car seems fine - is the GB about to go???
Thanks, Steve
The dreaded flashing arrow is dreaded because the transmission is -- with the exception of the engine -- the most expensive item on the car to replace. And in *some* cases a flashing arrow can mean it's toast. But that scenario is statistically in a tiny minority.
If the car seems fine and doesn't lurch forward from a stop, it's probably a minor fault picked up by the OBDII system.
Guest
Cheers Matt, the car is fine no problems with the box at all!! changes when it should and silky smoothmatthew1 wrote:The dreaded flashing arrow is dreaded because the transmission is -- with the exception of the engine -- the most expensive item on the car to replace. And in *some* cases a flashing arrow can mean it's toast. But that scenario is statistically in a tiny minority.
Am i right in thnking that my local Volvo dealer should read the codes for free?
They're the most likely to charge for it. But do call -- you never know. Call local Volvo mechanics and parts stores; they're more likely to read codes for free.
- 1377 Views
Last post by difflock54
- 1294 Views
Last post by Anders_H
