2002 S60 2.4T A/C
toddio
Year and Model: 240 1993 S90 1998
2002 S60 2.4T A/C
Post by toddio »
Hi folks:
Just got a 2002 S60 with 159K. I thought everything was in order. After changing registration, took it to get detailed, and the battery died. Jumped and ran right to auto parts store to get battery checked. On the way to the auto parts store, I had cold air for 5 minutes and then it started blowing hot. Battery was toast. Battery guy says that A/c is susceptible to shut down with a bad battery. That was a first for me. After installing new battery, cold for 5 minutes and then hot again. I am going to charge a/c and see what happens. Dilemma: From my view, I see a cap for a R134 fill connection near the rad. Is this the place to put the refill fitting? I can't get the cap off. It is marked "6nM. Does it just pull off, or is it threaded? I have been turning it counterclockwise, but it doesn;\'t come off. I don't want to force it. My last Volvo was a 97 s90, and that is where the a/c was recharged.
Any constructive criticism is welcomed.
I also need a repair manual. No Haynes, Chiltons are available. What is VADIS?
Thank you.
This is a wonderful resource.
Regards,
Toddio
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
the A/C port by the radiator is the high pressure port, leave it alone. The charging port(low pressure) is by the power steering reservoir, hidden under the hose coming out of the reservoir.
1foren
Year and Model: V70 T 5 2001
Post by 1foren »
Vadis is the one you want. It is Volvo's After Diagnositic Information System. It is a complete service software.
