Possible to read fault codes w/o a code reader?
I once read in an other Volvo forum that it is possible to read the codes by using the ignition switch in combination with the "READ"-button and the "taillight"-button. I have tried it on my XC90 - 2004, but it's not working. Does anyone know something about this?
JDS60R
- Been thanked: 3 times
Did you mean this ?
Diagnostics from turn signal.pdf- (83.79 KiB) Downloaded 6747 times
Retired
Yes, exactly!
But - I could not get it to work at the XC90 the last time I tried. It's possible that there is a small difference; the numbers to press the fog-lamp button. I will try it out later this night.
This worked, but no I'm full of questions... I need to know more about how to get the codes visible. When the display says "TCM checking" I guess there are no fault codes, but when it says "SRS DTC SET" I guess there are codes available?!
If someone out there know how to get further on, I would be very grateful for hints and tricks.
JDS60R
You need an OBD code reader or BSR PPC to get the codes or their defintions. The car will not show you the trouble codes any further than the doc I attached.
I would like every manufacturer to display the codes on the dash as they occur.
That being said - OBD readers are quite affordable on ebay or at harbor frieght etc.
Retired
The only problem is that the ODB code reader will not display any other codes than those for the environment. Unfortunately the PPC Diagnostic reader from BSR is impossible to obtain in Europe...
I know I have seen some more about the dash-display codes somewhere else. I have to do some more research at the SVXC forum....
Hi, I just went through this on my 2004 xc90. As someone allready wrote the OBD2 system only deals with emisions type codes for passing emmisions tests. These are genaric to all OBD2 type cars and makes.To read the other Volvo codes you need to go to the dealer or a Volvo shop that has the correct reader. Well that last thing I wanted to do is go to the stealer. So I first I went to my buddie that had a 6500 dollar 1 year old snap on machine and it would not do it even with a current software update. Next I called the dealer and they wanted 140 to read them. The next private pure Volvo shop wanted 100 to read them and the next Volvo shop wanted 40 bucks. I made sure with each that they had the right machine and they assured me they did or no charge. I went with the 40 buck guy and he was able to turn off my srs light and read my abs code and pointed me in the right direction to fix that.
Volvo made this very difficult for a reason for the average joe to work on these. Their own software has some very spendy software updates that the dealer has to pay. Just no way around it.
- 20 Replies
- 4828 Views
Last post by smacknab
- 3989 Views
Last post by mrbrian200
- 6136 Views
Last post by xHeart
- 2525 Views
Last post by TripleThreat719
- 1090 Views
Last post by Ozark Lee
