Does anyone know when Volvo switched from replaceable bushings to vulcanized bushings? The ones on my '95 are shot and I want to replace them if possible. I don't feel like buying a new sway bar for two cheap bushings.
Thanks,
Kevin
850 Sway Bar Bushings
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
I think that was one of the nicer features of the 93 model, along with replaceable ball joints. Some early 94's might have that too, but from then on, they are part of the sway bar itself.
You CAN buy replacement bushings...but from the looks of it, they are not fun to remove the old ones & install.
'98 S70 T5
2016 Chevy Cruze Premier
confused_al
- Year and Model: 1996 TLA wagon
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- Been thanked: 504 times
Yeah,
I am contemplating doing this "Energy Suspension" Standard 20-mm bushing:
http://www.autozone.com/autozone/catalo ... stid=29676
Maybe you can to do this and report back? Cheap enough at $20.
I ordered these in black this afternoon. The black have graphite impregnated in them. I will be trying to install them next weekend. I will keep you updated.cn90 wrote:Yeah,
Kevin Ireland
'07 S60R Sedan
'95 850 Turbo Sedan
'07 S60R Sedan
'95 850 Turbo Sedan
Thanks!
Please update us. Many people are in the same boat!
I don't understand this Volvo vulcanized bushing business. Many cars I have owned have separate bushings that are easy to replace!
PS: If the bushings you order have no slit, then I think you may want to cut a slit at the bottom so you can spread and slide in on top of the sway bar. My 1998 BMW 528i has this setup (slit at the bottom of the bushing).
Please do a DIY write-up including the size of your sway bar (I have 20mm sway bar). From what I understand, diff years have diff sizes, anywhere between 20mm, 20.5mm to 21mm!
OK,
I just jacked up the car for inspection. My FRONT sway bar bushing is cracked after 12 years 106K, but no significant gap between the bushing and the bracket yet.
I measured the dimensions in case anyone needs to buy the generic bushings (I have not replaced my bushings yet).
My car is 1998 V70:
- Sway Bar 20mm
- Bushing is 40 mm x 30 mm x 30 mm, with 5 mm at the bottom. See pic:
My car is 1998 V70:
- Sway Bar 20mm
I had to punt on replacing these on Saturday. When we got the bar off we found that the band that holds the bar is actually two pieces and they are press fitted together. When deciding how much work it was going to take to get them off we decided that Saturday was not the day to do it. I will probably now wait until I can afford the IPD sway bars.
Kevin Ireland
'07 S60R Sedan
'95 850 Turbo Sedan
'07 S60R Sedan
'95 850 Turbo Sedan
- 1904 Views
Last post by Legofan
- 1159 Views
Last post by Botbasher
- 9 Replies
- 5327 Views
Last post by precopster
- 1144 Views
Last post by oragex
- 454 Views
