Rough idle on 2002 V70T5
Scottfishel
Year and Model: V70T5 2002
Post by Scottfishel »
My V70 T5 started to idle rough this afternoon. The acceleration has a hesitation and roughness that is getting progressively worse in a matter of hours. Last month it was having similar conditions and I replaced a coil and all was fine. I rechecked all my connections to make sure nothing had come loose from the coil replacement and all was well. Is it common or possible that one of the other coils is failing? My vehicle has 107k on it and I have done only one major repair in 80k miles. I had to have some form of etc? replaced.
billshoff
Year and Model: 2008 V70, '12 C70
Post by billshoff »
My independent Volvo mechanic told me to replace all five coil packs at the same time to avoid five trips to his shop. He believes that 100,000 miles is the life of the coils. I don't know if he's right but I took his advice.
Scottfishel
Thank you for the response . It would make since to do this, unfortunately funds are low and only one unfortunate event is in the budget for this month. I limped the car to work this morning, bought the coil at lunch and put it on in the parking lot. Thanks again for your response.
1foren
Year and Model: V70 T 5 2001
Post by 1foren »
Did you change the Spark Plugs @ 80k? The other thing that can make it idle rough is a dirty or bad Mass air flow sensor.
Have you cleaned that lately? Rec. is every time you change air filter.
wcoastdl
Year and Model: 01 S80, 2.9
Post by wcoastdl »
Hey, I just had the same problem with my wife's S-80; rough idle. I called it surging. Took it to the dealer for, what I thought was going to be a $52.50 diagnostic, turns out, it was the throttle position sensor. They (VOLVO) fixed it for FREE! I guess with all Toyota's surging issues, Volvo isn't taking any chances. I didn't ask, I just said thank you very much and gave them my debit card.
Scottfishel
1foren, No I did not replace the plugs at 80K. I will plan on that this month. The mass air flow was cleaned last month. Thanks for the advise.
wscoastdl, Surging really isn't how I would describe the problem I had.
