Inner and Outer Tierod End replacement tutorial
This topic is in the MVS Volvo Repair Database » Inner/Outer Tie Rods DIY - S70, V70, 850, XC70
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
nlemerise over on Swedespeed shared this (also added to our database)...includes pictures...great write-up:
inner-tie-rods.pdf
(1.37 MiB) Downloaded 15788 times
code-man850
Year and Model: 855T '96
Post by code-man850 »
Yes I understand how it "should/would" come off. But I felt around for about ten minutes (thats a long time to feel around on one little part) and could not feel any flat spots anywere to fit a pipe wrench or any other wrench onto.
'96 855 Turbo
K&N, H&R, Mobile 1
Its a wagon thing...
You wouldn't understand.
Timberwolf530
Year and Model: 1994 850
Post by Timberwolf530 »
If you're going to replace it with a new one anyway, just use a pipe wrench. You don't need flat spots. They're designed to turn round things. I've used them for that in the past and you get lots of leverage.
1994 850 Wagon - My car is on it's 3rd generation in my family. "I don't look at it as doing repairs, I see it as doing a complete restoration one part at at time."
code-man850
Ahhhh ohhhhh, gotchya. I'll be tryin that this weekend.
'96 855 Turbo
K&N, H&R, Mobile 1
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2857 times
Been thanked: 1332 times
Post by matthew1 »
Fork in the road: Outer goes there, Inner stays here
Outer tie rod questions and tips on 850, S70, V70, XC70, and V70 XC older than model year 2001 let's put in Outer Tie Rod Replacement Tutorial - 850, S70, V70, XC70. Inner tie rod questions and tips we'll use this topic. It's not as though either inner or outer is that big of a job or terribly different from each other, but since we have two topics, might as well keep each focused. Thanks!
Also -> Amazon link
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 276 times
Been thanked: 84 times
Post by hausmeister »
Just some info from my experience:
Tried to replace the inner tie rod today, but I utterly failed. Couldn't get the old one off - I tried a wrench (and hammering ist) and also a pipe wrench... no chance (not enough space and also the metal just strips off). :x
I checked online and there are special tools for this to use with an impact wrench... like this
At least I couldn't do it... so my advice - either get the tool or have the shop do it if you are not sure you can get it open.
At least I didn't ruin it. :roll:
850 T5-R '95 auto Image
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
hausmeister wrote:Just some info from my experience:
I checked online and there are special tools for this to use with an impact wrench... (like this )
Is the method in the video for inner tie rod applicable to 1997 850 with TRW rack?
matthew1
Site Admin
Post by matthew1 »
I don't know if my 850 has a TRW, but the problem was the same. I too used a pipe wrench. The tool in that video looks like a lot of work to save a little work.
Also -> Amazon link
xHeart
Post by xHeart »
I am faced with same. But havn't given up yet. A good rest is what I need first.
Warren561
Year and Model: 2000 S70 5sp Auto
Post by Warren561 »
I am trying to source the boots in order to do this repair. I need the SMI boots (Volvo P/N 9191409). It appears that the only name-brand aftermarket for these is "KARLYN." Has anyone ever tried the KARLYN brand boots? Are they any good?
I'm seeing a 2 pack of KARLYN for about $30 on eBay vs $46 each for Genuine Volvo at TASCA.
