I did a forum search but couldn't find anything. Could someone provide "how to" instructions or post a link to a procedure description? I picked up a compression gauge at Harbor Freight but the instructions that came with it, among other things, say it takes two people.
Also......I would appreciate instructions on a "leak down" test which I assume would use the same pressure gauge.
Looking for instructions for testing compression...
Best to buy a compression tester that screws into the head and not a push on type as push on ones arent very accurate. These are the instructions found in the UK Spec Haynes Manual
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Here's a great article that will probably explain it to you more in-depth than I can, with lots of pictures. Pictures are good!
http://www.automedia.com/Engine_Compres ... 050801cc/1
The link to page 2 is kinda hidden, but you'll see it.
'98 S70 T5
2016 Chevy Cruze Premier
JDS60R
- Been thanked: 3 times
Here is another one for compression
http://www.volvospeed.com/Repair/compression_test.html
For leakdown you need a different testing rig. If you have two guages and a pressure regulator you can use the hose from the compression tester without the valve. Its better to have both testers. The leakdown tester helps pinpoint issues better than the compression guage. But both are very useful in diagnosis.
Retired
C@lvin
- Year and Model:
- Been thanked: 2 times
Great information. Thanks.
If it's not already there (I couldn't find this information searching the forum) it might be helpful to put this thread in the repair database.
Calvin
98 S70
00 V70
240,245,760,940,850 Turbo
98 S70
00 V70
zanzabar
- Year and Model: '07 V70, '84 245
- Been thanked: 4 times
If you can get the pressure gauge sitting in a position that you can see from the driver's seat, sure. But typically as the engine chugs you'll find that the gauge will shift or rotate or whatever and you won't be able to see it clearly. You really need someone else there to read the numbers for you or to crank the engine while you look at the gauge.Alecw81 wrote:Just picked up a compression tester today, is it possible to do this solo?
VW TDI refugee
LeMons racer ('84 245)
1994 855 (sold)
2007 V70 2.5T daily driver
1994 855 (sold)
jblackburn
Sure. My gauge holds the highest reading like a tire gauge until you reset it.
Do the test on a warm engine. Disable the fuel injectors and spark. Then hold the throttle wide open each time and let it crank through a few cycles (about 8 seconds/cylinder or so).
'98 S70 T5
jblackburn
Yep; you'll be done with that in under a minute. Just pop off the metal cover and squeeze the connector on each one.
'98 S70 T5
- 10 Replies
- 4282 Views
Last post by erikv11
- 12 Replies
- 776 Views
- 1767 Views
Last post by Livens
- 10048 Views
Last post by ChrisatXeMODeX
- 10004 Views
