93 850 GLT, 237k, TX
I have problems getting my AC to work after replacing the ECU (the replacement is identical to the original). I want to use a toggle switch to turn the AC on/off bypassing the ECU. I’d appreciate it if anyone knows how to do this or has wiring diagrams indicating which wires to connect to.
Thanks,
speedbump
How can I install a toggle switch for the AC?
- Year and Model: Many Volvos
- Been thanked: 75 times
Are you asking about the ECC or the ECU. The only place the ECU gets involved is after the A/C pressure comes up and the controller detects that the A/C is running. It changes the idle mixture and turns on the engine cooling fan but the A/C clutch is controlled by the ECC via the A/C relay and the low pressure switch.
You can run a wire from the positive battery terminal straight to the A/C clutch and bypass everything - but I wouldn't advise that you do so. A low coolant charge means no circulating oil which generally means a compressor failure and it can happen quickly.
It is the only wire that goes to the A/C compressor, towards the front of it. Again, I advise against this since it bypasses all of the safeguards that are in place to protect the compressor.
- 1045 Views
Last post by rspi
- 149 Views
Last post by InfiniteJESP
