Pulling the fuse or just disconnecting the fan behind the glove box is probably about the only way you can shut it off.
There's a link here that shows the location of it:
http://volvospeed.com/vs_forum/index.ph ... -no-codes/
A/C issues
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
'98 S70 T5
2016 Chevy Cruze Premier
here's a picture of the resistor:
http://www.fcpgroton.com/product-exec/p ... gory_id/78
search this site for blower motor replacement procedure and you can do it
I'd also replace the blower motor, and get the one with the squirrel cage attached
99 V70XC 158K
95 850glt 188K
95 850glt 188K
OK I thank you for you help but now I believe the Problem could be bigger...... I have the fan problem (problem 1) I just installed a new ecc and when I start the car it blonks 3 times then lights up like normak....... the temp works and the air direction works but the fan controls do not work....... but it gets better ...... I turn the headlight on for night driving and the ecc turns off........... I believe I have many problems at this point....... Please a good strating point .......
- Year and Model: Many Volvos
- Been thanked: 76 times
This sounds very much like an ignition switch issue with the additional details.
The good news is that it is relatively cheap and easy.
Lee Thank you so much....... I am going to throw a fan blower motor and blower resistor, a ecc at this in the am..... before I blow them....... why do you think it might be a ignition problem...... all other things in the car work right and all the fuses in the panel work the way the should....... the thing that scars me is that when I turn the head lights from auto to on (with the dash lights on) the ecc lights go out........... is there a power deverter for the ecc that would not make enough voltage ...... Like I said im thowing anything and anything at this to make it work...... and ps this is my first volvo at the age of 40 and I wish I bought one 20 years ago.........
Such that I can read it this sounds like a ground problem.
- 11 Replies
- 2623 Views
Last post by dimataeus
- 11 Replies
- 6347 Views
Last post by oragex
- 9 Replies
- 1929 Views
Last post by leapdragon
- 2143 Views
- 911 Views
Last post by precopster
