Hello
I Posted in the wrong Place before but still need help. Fan Runs all the time so I replaced The Blower Resistor and still blows high all the time even when the key is off. Pulled fuse 5 and the fan stops..... what else could this be...... even when the ecc is unpluged the fan runs on high all the time.....Please help.... Joe
1993 Volvo 850 blower motor resistor location
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
Joe, my ECC had the same “always on at full blast even when the key isn’t in the ignition” issue. The blower had burned itself out, and THAT blew out the MOSFET power state unit, so I bought a new one from FCP. Did you replace the resistor;
or the MOSFET power stage unit;
. . . which is the black device seen in Lee’s photo? You can only have one of them!
My understanding is that with the ECC setup, power goes from the battery, through the fuse, to the power stage unit, and directly to the fan. The ECC tells the MOSFET circuit how much juice to send to the fan. If the power stage has failed, it fails in the “open” position and it lets all the power through to the fan. So if that's the case, and you did indeed replace the power stage unit, you may have (another) bad unit on your hands.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
I know that this is an old thread but I just replaced my son's power pack on his 850. It was indeed the strange shaped unit on MCC (on his '94 850)- the one that is the upper picture here, that finally fixed the multi-speed blower. Now, if I could just figure out how to fix the heavy clicking when the blower is not on recirculate...
clarkandrew45
- Year and Model: 2008 Volvo S60
Hello there mod, I just check on that one earlier, Thanks i find that resistor easily because of the pictures. Thanks for this, really a big help.Ozark Lee wrote:The blower motor resistor (or power stage in the case of the ECC) is inset into the air duct directly to the right of the relay(s) that are shown in MIJ's picture. With the ECC there is only the A/C relay, on the MCC there is the A/C relay and the max speed fan relay.
elchopperfreak
- Year and Model: S70 T5 1999
I believe the clicking is the mechanism that shuts the system so the air recirculates.
I just removed the blower and resistor and noticed in my car it was broken so it was zip tied in the shut position
I agree with you for this one mate. That picture also helps me alot, i easily found that thing on when i have checked on that last night.clarkandrew45 wrote:Hello there mod, I just check on that one earlier, Thanks i find that resistor easily because of the pictures. Thanks for this, really a big help.Ozark Lee wrote:The blower motor resistor (or power stage in the case of the ECC) is inset into the air duct directly to the right of the relay(s) that are shown in MIJ's picture. With the ECC there is only the A/C relay, on the MCC there is the A/C relay and the max speed fan relay.
If you are blowing the thermal fuse in the power pack control module try pulling the fuse and letting it reset. The fuse will reset, but the main cause of the thermal fuse blowing is high load in the circuit and this is usually caused by warn out blower motor brushes. The brushes wear down to zero rather quickly (50-60k miles on the car...), so don't be surprised when you start having blower problems. If you are going to the trouble of replacing the power control module, take a look at the blower motor itself. Pull it out of the duct housing, remove the motor from it's shroud and inspect the motor brushes. A new Bosch motor is only about $75 from FCPGroton and well worth it. They're cheap but don't last long, nothing you can do about it. Good luck.
Hold My Beer And Watch This !
- 3034 Views
Last post by Lbrasher
- 905 Views
Last post by SilverVolvousa
- 46 Replies
- 12504 Views
Last post by 93Regina
- 1385 Views
Last post by Tobers
- 1071 Views
Last post by JRL
