To everyone @ site,
Best help online ever! Volvo for life! One more question though, How do I reset service light after home oil change?
How to reset a service light after an oil change
Moondust70
- Year and Model: V70 2003
here you go ................. taken from our Volvo UK forum site...........
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on.
Note! If the lamp flashes, it may be because one of the service parameters has not been programmed.
Proceed as follows to reset the service reminder indicator (SRI):
-Ignition position I
-Press and hold in the reset button for the trip odometer
-Ignition position II
-The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
-Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded.
Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
Resetting the service reminder indicator (SRI), model years 2002-
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 s each time the ignition is switched on.
-Ignition position II.
Note! Turn the key to position II within 2 seconds.
-Hold the reset button for the trip meter pressed in until the original value has been reset.
Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
-Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
-If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds.
Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
- Has thanked: 2866 times
- Been thanked: 1332 times
Welcome to both you two new members.
For those stumbling onto this topic, here's our official Reset Your Volvo Service Light tutorial, and it has a bunch of follow-on comments about subtleties for different models/years/methods. Nothing wrong with asking questions like this though.
- 11 Replies
- 16148 Views
Last post by RossJonnes
- 27 Replies
- 7795 Views
Last post by Blockpartie
- 13 Replies
- 6226 Views
Last post by esl_97_850_T5
- 2007 Views
Last post by precopster
- 41 Replies
- 9531 Views
Last post by slickdizzy
