Goos day everyone. I own a '95 850 GLT. I need to change some light bulbs from the instrument panel, any tips how to dissasemble it, I don't want to break any piece !!!
Thanks, Dimas.
instrument panel light bulbs
- Been thanked: 504 times
Every single tips/tricks is mentioned here:
DIY: 1998 Volvo V70 Instrument Cluster Removal/Bulb Change
https://www.matthewsvolvosite.com/forums ... 4&p=126022
confused_al
- Year and Model: 1996 TLA wagon
Here is the instruction to take cluster out (up to step 16):
https://www.matthewsvolvosite.com/2005/0 ... ix-how-to/
You might want to replace them all once you are there. You can buy them cheaper
http://www.12velectronics.com/servlet/t ... Categories
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Replace all bulbs: well I would not do that b/c one thing I have learned about light bulbs in general is that: they may last 1 day, they may last 20 years.
Anyway, the cost is low, so if you replace them all, you are not out of money.
* READ my trick above, some of the bulbs are accessible from below (no need to remove the cluster!).
confused_al
His is 95, so the configuration is a bit different...
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
My DIY is for 1998.confused_al wrote:His is 95, so the configuration is a bit different...
1998 and 1995 are slightly different, but not much.
confused_al
What i am saying is for 850s, there is no need to remove the whole dash cover in order to get that cluster out:
http://volvospeed.com/Dashremove.htm
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
whoa
- Year and Model: 850 Turbo Wagon 1996
Maybe, but for one thing it's a pain to squeeze the cluster out that way, for another you risk scratching it, and for another you are bending the dash in a pretty dramatic way that I'd worry would lead to rattles and squeaks.confused_al wrote:What i am saying is for 850s, there is no need to remove the whole dash cover in order to get that cluster out:
You're right that you don't have to remove the whole dash cover, but it only takes 5 or 10 minutes to unfasten the right/passenger side of it as well, and it makes removing and replacing the cluster so much easier.
1996 850 Turbo Wagon
LMAO,
So the "proper way" for a 1993-97 model is still the same as my DIY (post #2 above).
It is only a few more screws to remove and life is much much much easier with the dash trim out.
The Bay 13 DIY is kind of "cutting corner" technique.
- 1504 Views
Last post by Mr. Detail
- 514 Views
Last post by rspi
- 5204 Views
Last post by AVOIT17
- 3207 Views
Last post by zwieback
- 996 Views
Last post by CIK7
