Hey Everyone,
Heres a good one. I have had for quite some time a noise that sounds like jingling keys coming from somewhere underneath my 850. I hear it with the windows open while hitting bumps. I did struts and rear brakes in the fall and most recently the drivers side axle. This noise was here before all these were done and continues today. Had it on the lift at my friends garage and we can't figure it out. Everything appears tight in the suspension. This has been a tough one to figure out. Any ideas on this would be great. Thanks Frank
See if you can diagnose this noise
cronce66
- Year and Model: 850 Turbo, 1996
Perhaps this is the same noise that was on my car. I recently did pads and rotors all around, but I ended up breaking off the old parking brake shoe lining on one side taking the rear rotor off. Since I didn't have a set of parking brake shoes with me, I loosened the parking break cable quite a bit just to take tension off the shoes. Ever since, I get a jingling sound that I can hear when my window is open. Perhaps you'd want to check to see if the cable is loose on your car? Just my 2 cents....
-Lee
-Lee
1996 850 Turbo - Black
V70Johnson
- Year and Model:
Had a similar noise from underneath my V70. Intermittent yet annoying. Finally traced it to the front end, passenger side. The backing plate behind the brake rotor was slightly bent making contact with the rotor under certain conditions. Simple fix. Might be worth investigation.
Check the drop links [swaybar links] they're a common area for failure and will clunk and click as you go over bumps as will a broken caliper spring.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
Jack Rock
- Year and Model: 1998 V70R
I had a similar sound in an old dodge I had. Sorry, only 3 weeks volvo experience. Anyway, the radiator was rotten and the fins were coming off bit by bit, getting thrown by the fan onto the engine, under the vehicle and hitting heat shrouds creating a 'key jingle' sound. No kidding.
1997 850 T5 (gave up at 324,000km)
1998 V70 R AWD (gave up at 296,000km)
1998 S70 T5 (total loss - in a parking lot!)
1999 V70XC
1975 VW beetle
1960 Empi Sportster Dune Buggy
1999 V70XC
1975 VW beetle
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
If this were on a '55 or '56 Chevy, I'd say it's a hanger in your exhaust system. The resonant frequencies of combustion caused the "tinkling". Most of them did that. Maybe worth checking.
fiore67
- Year and Model: 93 850. 95 850
I think i've figured out the jingling noise. The u shaped piece that fits on the a-arm that works as the bump stop. Both sides are loose that you can tap it with your finger and BAM......jingle bells. Amazing !!
- 13 Replies
- 1824 Views
Last post by ashlee2319
- 2790 Views
Last post by Legofan
- 1294 Views
Last post by wanderdüne
- 6713 Views
- 2270 Views
Last post by ndphotonl
